1. blweldon2's Avatar
    My Note 2 is having some bad GPS issues. The GPS works just fine in Maps, but if I try to find my location in Accuweather or Redbox, it doesn't find anything. This phone is brand new and isn't having any other problems. Any advice?
    11-22-2012 12:19 PM
  2. inspectagadget1973's Avatar
    It sounds like theirs nothing wrong with your gps. It sounds like those apps aren't working properly. And I'm sure you're set up to recieve updates for all your apps automatically. So, you could return if you're within your 14 day purchase period. That sounds like your only option but I doubt it would solve your problem with Accuweather and Redbox.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    11-24-2012 08:02 AM
  1. Google Maps GPS problems
    By Fairbanks in forum Verizon Fascinate
    Last Post: 03-15-2011, 06:53 PM
  2. GPS problem
    By southpawmedic#IM in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 08-07-2010, 09:46 AM
  3. vibrant gps problem?
    By CarliCruise in forum General Help and How To
    Last Post: 07-29-2010, 08:38 AM
  4. GPS problems, even after fix
    By thenameisgabe in forum AT&T Captivate
    Last Post: 07-26-2010, 07:45 AM
  5. gps problems
    By PRNmeds in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 03-23-2010, 01:37 AM
