Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Like Tree1Likes
    Simone Lam's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Heelp pleasse! Samsung Galaxy Note 2 will not lock!
    So I have gone onto settings-lock screen- and then put in a screen lock. I also have "lock instantly with power key" ticked and I have set it to lock automatically. I have been trying to fix this with all different settings all day but for some reason, when I click the power button on the side of the phone to lock the screen, it doesn't lock! The phone screen goes black (as it should) but then to unlock, it doesn't ask me for a password. Am I missing something here?? Surely this should be simple. Everyone can use my phone..
    (Another note: If I'm on my phone and I open up my messages in the pull down notification menu, it does ask me for a password, but this is the only time it does)
    I can't find anything on this online. Someone please heelp!
  2. #2
    Victor R's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Heelp pleasse! Samsung Galaxy Note 2 will not lock!
    I know it sounds simple. But, did you restart your phone?
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
  3. #3
    Mickeywdw1254's Avatar
    Posts
    Global Posts
    34 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did you adjust the "secured lock time" settings?
    Attached Thumbnails Attached Thumbnails Heelp pleasse! Samsung Galaxy Note 2 will not lock!-uploadfromtaptalk1354491299017.jpg
    Simone Lam's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yep. I've done both of these...
    HOSTILEDUTY likes this.
  5. #5
    aaronbuescher's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock JellyBean
    Just tried to set up mine and I have the same issue. Prob. a software Issue.
    Sent from my White Galaxy Note II
  6. #6
    JayRatliff's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just lower your timer to 15 seconds, it will get you by until the update. Not finding any other references to this occurring commonly.
    Just tested mine and it works fine, however, I am using the pattern lock, not a pin code lock. You might try the pattern lock and see if it will work.....
    Simone Lam's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok so I've tried a pattern, password and pin lock.. with no success.. I've tried the "lock instantly with power key" and I've changed the timer to screen lock in "15 seconds after screen automatically turns off". I've called Samsung helpline and they told me to switch it off and take the battery out- but that didn't work either..
    @acbuescher - let me know if you find a solution! Thanks for the replies
  8. #8
    JayRatliff's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You could hard reset your phone if it is a software issue occurring randomly.
    1. Backup all your data
    2. Hard reset your phone Hard Reset Found Here
    3. Restore your data
    Not sure how savy you are, but you cold flash the stock ROM back in an attempt to fix the problem.
  9. #9
    inspectagadget1973's Avatar
    Posts
    Global Posts
    58 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Simone Lam View Post
    If it was me is take it back for a new one
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
  10. #10
    chloe s's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey my phone was doing the same thing. I went to security and screen lock then put it on swipe and pressed home. Let me know if it works for you!
  11. #11
    GarTheConquer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Same thing is happening for my Note 2. Got this lovely device yesterday and I still can't get the screen to lock more than once. I tried the battery removal. I am going to take it back tomorrow.
  12. #12
    DroidXcon's Avatar
    Posts
    Global Posts
    11,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock for now
    Quote Originally Posted by GarTheConquer View Post
    Did you do.a factory restore?
    From my Galaxy Note 2 via Tapatalk
  13. #13
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'll try that today and report back. I read somewhere that I must wait until some kind of setup is complete before signing in with my Gmail account because of this"no lock screen glitch."
  14. #14
    Steve Parkinson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Talking Re: Heelp pleasse! Samsung Galaxy Note 2 will not lock!
    Here's what you do.
    1. Settings > Lock Screen > Screen Lock then set your pin
    2. On the same Lock screen setting screen > Secured lock time > Instantly with the power key or when the screen times out
    Done. When your screen times out or you press lock key. Press lock key again and it'll ask you to enter the pin.
    As stupid as it sounds, this screen lock is considered "Secured lock" which requires another timing set up regardless of your display time out settings.
    p.s. You don't need to lower this secured lock by 15 seconds. You can have it locked instantly or whenever your other display time out setting kicks in. This feature is to allow people to not having to put in the pin every time their display is turned off, but only if it's off by X minutes.
  15. #15
    Daogeii Junhao's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My note II straight went into home without asking me to swipe the screen , what happened to my phone ???
  16. #16
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine is working perfectly fine.
    Lock screen and password feature works.
    Maybe return it and get a new one...
  17. #17
    Varun Singh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    lol exact same thing happend wid m also i freaked out as well..
    just uncheck lock immedtialy wid power key ,
    and go to lock automatically> immediatly
    and tada it will be all normal
    hope this works
  18. #18
    Basheer5277's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Smile Re: Heelp pleasse! Samsung Galaxy Note 2 will not lock!
    Hi I got solution you press the power key until u see the Samsung note 11 after restart problem solve
  19. #19
    rms2005's Avatar
    Posts
    Global Posts
    79 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was having the same problem and after playing with it and many apps it turned out to be something with gosms, once i uninstalled go the lockscreen worked fine, reinstall it and the problem comes back. Been with handcent for about 24 hours now and not one problem.
  20. #20
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm guessing her lock screen is working now..???
  21. #21
    sitetalk facebook's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Use All in one toolbox and clean your system...and your note 2 will lock again!!! I had this problem too! Try it and you will see! Love and peace!
  22. #22
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ALL IN ONE TOOLBOX application from google play! Install it! Press quick boost!!! Press power button. Then again press the power button! Lock works now!!! WOOOW. Satisfied?? Hope will work for you!
  23. #23
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ...or install ACTIVE LOCKSCREEN from google play! Cheers!
  24. #24
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try MX HOMESCREEN or ACTIVE LOCKSCREEN!
  25. #25
    cazan99's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi, I have the Samsung Galaxy Note I and it recently did an automatic jellybean update.... and my screen lock will not work either.... have double checked all steps
  1. Samsung galaxy note gallery not working
    By anon721037 in forum Introductions
    Last Post: 06-21-2013, 09:38 AM
  2. Replies: 1
    Last Post: 12-16-2012, 08:33 PM
  3. Samsung Galaxy S II Not Making Its Way to Verizon
    By Preach2k in forum General News & Discussion
    Last Post: 08-31-2011, 01:15 AM
  4. galaxy tab will not let me access settings tab?
    By edarby00 in forum Samsung Galaxy Tab
    Last Post: 08-25-2011, 11:33 AM
  5. GPS will not lock after root and ROM
    By d1ez3 in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 05-28-2011, 05:43 PM
