1. Burnes's Avatar
    Whenever I try and connect my Note 2 to wireless it connects several seconds and disconnects. I have search and tried the Settings>Advanced and tried the 3 alternatives for "Never Sleep" etc. but none of the make a difference and I have restarted. In fact, I had a true keek mobile engineer witha Galaxy 2 try the same procedure on his G2 and his worked fine. I think maybe AT&T's "value added" wireless network finding software might be the culprit. Does anyone know why I can't do something as simple as mu old iPhone could do with wireless net connections all over the world?
    Chuck Adams likes this.
    12-04-2012 09:44 PM
  2. Mustard's Avatar
    WIFI disconnecting constantly
    try disabling ATT Smart wifi
    ska916jedi and Chuck Adams like this.
    12-04-2012 10:44 PM
  3. jdub1981's Avatar
    Yep disable smart wifi. I made the mistake as soon as I got my note as well. Infact I took all the att apps and hid every single one of them
    - - - Updated - - -
    12-05-2012 05:41 PM
  4. bc1940's Avatar
    I've been having the same problem of WiFi working okay at home but disconnects after 1-2 seconds on any other WiFi. How do you disable only the AT&T Smart WiFi without disabling all WiFi?
    12-11-2012 02:55 PM
  5. Mustard's Avatar
    Settings> Applications Manager> ALL.
    Then look for ATT WIFI. Click open then click disable
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    Chuck Adams and bc1940 like this.
    12-11-2012 05:32 PM
  6. Rene Voss's Avatar
    That worked. Thanks!
    12-29-2012 08:46 PM
  7. jdub1981's Avatar
    This seems to be an ongoing problem. I had a friend call me tonight and had this same issue. Except that when he first got the phone I purposlly went and hid the app from him so he couldnt turn it on. Seems it may be to turn itself on. I had to walk him through unhiding it and turning it off by phone.
    Also, Smart Wifi has nothing to do with Samsungs built in wifi. It has more to do with ATT's 25000 hotspots, such as the ones at starbucks. Disabling smart wifi does nothing but stop ATT's faulty app. You can still go to these same stores and connect their wifi you just hace to do it the same way you connect to your home wifi.
    12-29-2012 11:57 PM
  8. TheOtherBill's Avatar
    Did your friend just get the update? I installed it 2 days ago and now I see it updated and turned on 4 or 5 apps I had disabled. The nice thing was once I hit "uninstall updates" for each app they were disabled again.
    12-30-2012 12:03 AM
  9. jdub1981's Avatar
    My friend isnt as technologically savvy as myself. He waits for me to figure stuff out and then I make the changes to his phone for him.
    12-30-2012 12:23 AM
  10. sk8ordie72's Avatar
    I had the opposite reaction. My wifi at my ex's would connect for about 10secs and then I'd have to re enter the passcode, someone told me to use AT&T Smart Wifi and haven't had the problem since???
    12-30-2012 02:45 AM
  11. jian126666's Avatar
    I just bought a new note 2, but its cant connect to wifi, sometime can sometimew cant, any1 can help me??
    04-06-2013 05:07 AM
  1. Connecting to Adhoc wifi networks from Samsung Galaxy Note 10.1
    By PaulMacc in forum Samsung Galaxy Note 10.1
    Last Post: 08-14-2013, 01:29 PM
  2. ATT Samsung Galaxy Note with S-pen (Pen question)
    By enduser2941 in forum AT&T Galaxy Note
    Last Post: 05-01-2012, 11:49 PM
  3. Samsung Galaxy Note ATT i717 Hacked for T-Mobile 4G
    By kwilsonjr in forum Samsung Galaxy Note
    Last Post: 04-11-2012, 07:42 AM
  4. $149 for att samsung galaxy note
    By markawashington in forum General News & Discussion
    Last Post: 02-25-2012, 10:28 AM
  5. how to geet non market apps on att samsung galaxy tabs
    By staticleader in forum Introductions
    Last Post: 06-06-2011, 09:57 AM
