09-19-2014 06:50 AM
47 12
tools
  1. joe.kent's Avatar
    So recently, my phone has started to lose data connection. This happened once before, and I read about disabling AT&T Smart Wi-Fi, which seemed to fix the issue until this week. I have to restart the phone and data works fine, but if I quit using it for a while I have to do the process all over again. Wi-Fi toggle is off, OS is stock, anyone have any ideas?
    12-26-2012 07:34 PM
  2. joe.kent's Avatar
    So after talking with AT&T throughout last week, they are suppose to "follow up" with me again today, and said since I'm still having the issue, send me a different phone. AT&T tried reentering my IMEI number, I've tried using my wife's SIM card from her S3, nothing seems to fix this. When the data stops, I can connect to Wi Fi and everything starts to work. Does this sound like an antennae issue on my device? Anyone have a clue what's going on with it?
    12-30-2012 11:10 AM
  3. DroidXcon's Avatar
    When you get a chance go to settings> more> Mobile networks> access point names> hit the selected access point
    Post up what the settings are please.
    From my Galaxy Note 2 via Tapatalk
    12-30-2012 04:05 PM
  4. joe.kent's Avatar
    Here u go
    Attached Thumbnails Note 2 loses data connection-screenshot_2012-12-30-16-11-57.png   Note 2 loses data connection-screenshot_2012-12-30-16-11-46.png
    12-30-2012 04:17 PM
  5. DroidXcon's Avatar
    Here u go
    Weekend my wife gets home ill compare the APNs and maybe have you modify yours to match and see if that helps
    12-30-2012 05:15 PM
  6. joe.kent's Avatar
    Sounds good... went by AT&T earlier and the slapped in a shiny new sim card.. wanted me to try that.
    12-30-2012 07:02 PM
  7. DroidXcon's Avatar
    Ok so she has the Galaxy Note (original) here settings are almost the same except
    MMS=not set
    MMS proxy = not set
    MMS port= not set
    APN type=internet
    12-30-2012 07:17 PM
  8. joe.kent's Avatar
    About 18 hours after the new SIM card and it's still working. Before, I would have restarted atleast 3 times.. Guess it was the SIM.
    12-31-2012 12:29 PM
  9. DroidXcon's Avatar
    Great congrats:thumbup:
    12-31-2012 12:56 PM
  10. ItsaRaid's Avatar
    DroidXcon.....your awesome! Thank you for your help. This Note2 simply is the best device I've ever owned or used.
    DroidXcon likes this.
    12-31-2012 01:07 PM
  11. surebuttercringe's Avatar
    I know this is an old thread, but I am having the same issue with my Note 2. In wi-fi, it works fine but even with 3 bars of 4G, the internet only works for about 15 minutes before giving out. If I let it sit for a few minutes, it will come back and work for another 15 minutes before repeating the process all over. Is this an antenna issue or can it be resolved in the settings?
    Sent from my Samsung Galaxy Note 2
    02-15-2013 05:05 PM
  12. joe.kent's Avatar
    I finally gave up and I'm just dealing with mine, after 2 days of a new SIM, my phone started acting the same, and has ever since. The quickest temp fix for it is to go into settings, then go to more settings, then to mobile networks, and toggle the mobile data checkmark. Turn it off for a few seconds, then back on. It will work fine for a while, then you will have to do this again. I go through this process about 5 times a day currently. AT&T has quit returning my phone calls about the 300.00 device that has had issues pretty much out of the box.
    02-16-2013 10:14 AM
  13. GMJeff's Avatar
    I have had similar issues since the update to the premium suite. The wifi would have similar issues though.
    When I am at home, my note 2 would appear to drop the connection and my data would stop working. The simplest websites would not load, and I have a rather fast Internet connection, and my router works properly with other devices.
    At work, on 4g service, same thing as mentioned previously. Three bars of service and no data. Like I wasn't even connected to the network. Then I turn on airplane mode and then off to restore data. It works for awhile, then later it does the same thing.
    At&t just released a update yesterday that has apparently fixed my wifi issue. As for the issue of mobile data, I haven't been able to test that yet. Maybe the update had some newer chipset drivers or patches included that could have tweaked a few settings.
    Sent from my GT-N8013 using Android Central Forums
    02-16-2013 11:55 AM
  14. Kelly Kearns's Avatar
    Are people having this issue only on Wi-Fi? This thread has become confusing. If it is Wi-Fi only, there are some settings to check, even one on a hidden menu.
    Sent from my AWESOME Note 2
    02-16-2013 12:00 PM
  15. joe.kent's Avatar
    My original post was for Data, WiFi works like a charm on my phone... it's cellular data that drops on mine..
    Kelly Kearns likes this.
    02-16-2013 12:02 PM
  16. Kelly Kearns's Avatar
    If AT&T stops returning calls, you call back, get Supervisors, if you are having an ongoing issue that isn't being solved, tell Customer Care you want to speak to someone that has the authority to open an ICU Case for you.
    02-16-2013 12:03 PM
  17. joe.kent's Avatar
    What update would that be? As far as the update that came down recently <72 hours ago, I heard it was only for a security issue..
    02-16-2013 12:04 PM
  18. GMJeff's Avatar
    Yes, the security update. I installed it and my wifi issues have disappeared since then. Whether they come back again has yet to be seen.
    Sent from my GT-N8013 using Tapatalk HD
    02-16-2013 12:07 PM
  19. Kelly Kearns's Avatar
    It is not unusual for Samsung to also include a fix they are aware of for something totally unrelated to the fix they are rolling out.
    02-16-2013 01:11 PM
  20. surebuttercringe's Avatar
    4G only. Works great on wi-fi.
    02-17-2013 09:27 AM
  21. Kelly Kearns's Avatar
    Are they working on turning on 4G in your area?
    Also, Samsung has a Tier 2 level of support also that they will switch you to pretty quickly, might want to call Samsung.
    02-17-2013 09:31 AM
  22. surebuttercringe's Avatar
    Nope. In Houston, 4G is pretty much everywhere, especially at work where I use it the most. I've even gotten speeds of 64 mbps download before in certain areas.
    02-18-2013 08:20 AM
  23. Kelly Kearns's Avatar
    Sorry, I didn't mean 4G, meant LTE.
    02-18-2013 08:30 AM
  24. surebuttercringe's Avatar
    Yes. All of Houston is LTE.
    02-18-2013 06:39 PM
  25. Kelly Kearns's Avatar
    Well I know working on LTE that can happen and also I'm in a low signal for LTE and the low LTE signal can cause me some problems.
    02-18-2013 08:06 PM
47 12
  1. Constantly losing data connection
    By Helgaiden in forum Virgin Mobile Optimus V
    Last Post: 03-24-2011, 05:33 PM
  2. Losing data connection for certain things..
    By intheb0x in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 10-04-2010, 02:58 AM
  3. losing data connection after signal drops
    By iluvmonkeys2 in forum Motorola Droid
    Last Post: 08-19-2010, 01:14 PM
  4. Losing data connection in multiple places
    By meesh in forum General Help and How To
    Last Post: 08-04-2010, 05:50 PM
  5. Incredible losing data connection
    By brandonx1000 in forum Verizon Droid Incredible
    Last Post: 05-04-2010, 03:42 PM
