04-03-2013 09:14 AM
44 12
tools
  1. sqa4life's Avatar
    sick
    I know u r just jealous
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    12-31-2012 01:13 AM
  2. jdub1981's Avatar
    I am on cleanROM 3.5 and how do you like my battery usage? I am using email heavily.
    Are you using the perseus kernel? Also did you start with 3.5? I have 3.3. I dont want to factory reset and install a new os. Can I just update it without installing new?
    12-31-2012 01:14 AM
  3. SenseMonkey's Avatar
    Has anyone noticed that the text messages is out order. Like when u send a message they will respond and then it puts their messages together
    Yes! I did. I deleted the whole thread and it fixed the problem tho.
    Sent from my Behemoth of a phone, the Galaxy Note 2
    12-31-2012 10:28 AM
  4. MatroxD's Avatar
    Lol!
    12-31-2012 01:40 PM
  5. acordo01's Avatar
    I am having trouble sending and receiving mms after the update any one else having that problem? They won't send or receive. I'm on att and i performed a clean install after the update because i was rooted before with clean room 3.5. And i wanted stock.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    01-01-2013 01:09 AM
  6. planoman's Avatar
    Nope, my MMS is working fine.
    acordo01 likes this.
    01-01-2013 11:59 AM
  7. incastillo's Avatar
    Sweet. You are the man. I hate how AT&T not only takes forever to do updates, but also mess up the options confusing everybody with back compatibility
    01-17-2013 08:00 PM
  8. 2happy's Avatar
    I also am disappointed AT&T won't let me change the notification panel icons. I would move them around so I don't have to scroll to get to Bluetooth.
    Thanks!
    Exactly that! I just spent over an hour looking around in my phone trying to find how to move my bluetooth icon. I know I did it when I first got the phone. Great update, but they really screwed up that part.
    01-18-2013 07:08 PM
  9. darnatl's Avatar
    I am running cleanROM 3.3 (jb 4.1.2) and I noticed I need to add sync if I want it on the notification bar
    Does CleanRom have an "airplane mode" button on the notification bar? I do not notice it in the above picture. If not, that is just as dumb as ATT leaving out the "sync" button.
    01-18-2013 10:25 PM
  10. MatroxD's Avatar
    If you have the Ace version (with any version that has the lidroid settings), if it's not on, you have to go in and turn it on in order for it to show.
    Sent from Note 2 via Tapatalk
    Attached Thumbnails Problem after 4.1.2 update.-uploadfromtaptalk1358580928172.jpg   Problem after 4.1.2 update.-uploadfromtaptalk1358580946471.jpg
    darnatl likes this.
    01-19-2013 01:36 AM
  11. RyDawgBoston's Avatar
    My portrait and landscape mode freezes up and will not work unless I do a reboot. I guess it's a very known issue.
    01-27-2013 02:00 AM
  12. avellancrf's Avatar
    hi guys... I just update my phone yesterday to 4.1.2 and the wifi conection does not work any more.
    Do anybody know how can I sole it?
    thanks
    02-12-2013 10:03 AM
  13. dakid2k6's Avatar
    Im doing a ton of research and just cant find what Im looking for. I just upgraded to the Note 2 yesterday after long thinking of which to upgrade. I just upgraded to 4.1.2 and so far ok. however I want to stop the notification of wifi being connected to a network, and i cant see the notification panel section in display as I see on youtube and all over the web. Any ideas Please?
    02-13-2013 12:38 PM
  14. aaronbuescher's Avatar
    What do you mean da kid?
    Sent from my White Galaxy Note II
    02-13-2013 08:57 PM
  15. dakid2k6's Avatar
    When ever I connect to wifi I have an ongoing notification in my notification bar. I want to know how to rid it. Also I have seen and read that in this 4.1.2 update you can customize your notification tray. However I don't see where this is possible. As I don't have the option to do so in my settings menu.
    02-14-2013 02:33 AM
  16. aaronbuescher's Avatar
    i have noticed that on my school wifi and starbucks wifi, like you have to go to the webpage and sign in. That has always been there for me though.
    02-14-2013 10:07 AM
  17. dakid2k6's Avatar
    Yea. Mines always shows even when I'm on my house wifi.
    02-14-2013 02:45 PM
  18. wyndslash's Avatar
    ++ There's a new version 3.5, you should check it out.
    And I'm not sure whether stock has all of our options such as that screen.
    yes, it has that screen. i'm running stock.
    03-18-2013 09:16 PM
  19. rcswamy's Avatar
    After installing new version of Android, I noticed that sync is turned off. I am unable to turn it on. The toggle Account & sync is not there in settings. Can anyone help me in turning on sync?
    04-03-2013 09:14 AM
44 12
  1. WiFi Problem after 4.0.4 update
    By h2opoloplyr_11 in forum Verizon Galaxy Nexus
    Last Post: 04-19-2014, 01:55 AM
  2. Problems after 4.1.1 update
    By bassdelux15 in forum Samsung Galaxy S3
    Last Post: 10-28-2012, 11:33 AM
  3. Rooted, but Recovery problems after 2.3.4 update...
    By xyp in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 02-04-2012, 02:35 PM
  4. Data problems after 2.3.6 update..
    By MAGiK9 in forum Samsung Galaxy S II Skyrocket
    Last Post: 12-19-2011, 07:58 AM
  5. Browse problems after update...
    By CavemanOOGA in forum Motorola Droid
    Last Post: 12-11-2009, 04:21 PM
