After the update, I intially sensed that battery usage has increased or is less than the stellar performance I had on 4.1.1.
I have been paying attention more so lately and I have to say it did indeed change. It still seems good, but it certainly appears to be using battery " more rapidly " than previously.
Anyone else noticing the same? I also noticed after the update there was alot more apps or things running in manage apps> running than previous on 4.1.1.
Something is using more battery?
Charge times are faste
Solution found★★★★★★
Disable all att apps put them 8n folder after disabling
