Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By Scott Kenyon
  • 1 Post By kgk1985
    Melvin Soo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Samsung Galaxy Note 2 could not connect to pc
    Recently i have bought a Samsung Galaxy Note 2 and i tried to connect to my pc but it didnt work even thou i have enable the usb debugging.
    i have google the problem but it seems that they say something about the USB Utilities. i couldnt find my USB Utilities option in my phone, there is only Kies via wifi. I would like to know how to fix this problem thanks
  2. #2
    Scott Kenyon's Avatar
    Posts
    Global Posts
    2,189 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MoDaCo Switch Beta 8
    Default Re: Samsung Galaxy Note 2 could not connect to pc
    You need the Samsung usb drivers. I believe you can get them here.
    http://droidviews.com/2012/samsung-m...ny-lg-zte-htc/
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    Raakaysh Shukla likes this.
  3. #3
    lostchild's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When I plugged in my AT&T Note II to both Windows XP and Windows 7 notebooks, they both auto installed usb driver and recognized the phone.
  4. #4
    kgk1985's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    DO NOT install the drivers that windows update recommends. That will overwrite the Samsung driver and cause issues. I had that issue. Go to sammy website and dl those and it will work
    sent from Galaxy Note 2
    Scott Kenyon likes this.
  5. #5
    Posts
    Global Posts
    2,189 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I agree. Don't use the junk windows installs. Also, installing them in Windows 8, you need to run the installer in win 7 compatibility mode. Took me a few minutes to remember you can do that.
    Sent from my Galaxy Nexus using Android Central Forums.
    If I have been helpful to you, please go to the store, buy a bunch of beer, and send it to my house.
  6. #6
    BeRich's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just wanted to point out it could be the USB cable you're using. I used a different USB cable with my N2 and nothing was showing up for it on my laptop until I switched back to the OEM cable. Then it worked just fine. Go figure.
  7. #7
    arberlimani's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi , can you help me i couldn't find USB driver for Samsung Galaxy note 2 for windows XP.
    best regards
  8. #8
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Uribam View Post
    DroidViews | Android USB Drivers: Samsung/ Motorola /Sony/ LG/ ZTE/ HTC/ ASUS/ Huawei/ Acer/ Amazon
    This link don't work. can you know another link
  9. #9
    eds817's Avatar
    Posts
    Global Posts
    2,709 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm using Samsung Kies and don't have to connect to the computer. It's all done wireless. Works like a charm.
    SAMSUNG KIES
  10. #10
    Jennifer Baui's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    my loptop cant recognized my note 2. i want to download musics from my computer but when i connect the USB to my computer along with my note 2. my loptop didnt recognized it
  11. #11
    Androlien's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thats right, I have four usb cables, and one of them did work.
  12. #12
    hack0160's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i tried... doesn't work...
  13. #13
    mmohn01's Avatar
    Posts
    Global Posts
    390 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have you tried going into developer options and clicking debugging?
  14. #14
    gliderider's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Too late. I already did. Now what?
  15. #15
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Message to all about not being able to connect:
    My experience with this is that if you have multiple usb ports on your computer and have front port access these typically dont perform as well as the ones on the back directly connected to the mobo. Also about monthly I have to reinstall the sammy drivers cuz windows overides my driver choices.
    Also if you tried installing drivers and that still doesnt work then try this: once connected the pc and the phone is recognized by the chime, unlock the device and go to your notifications. You should see an icon that says something about usb connection options. Click that and it will show you what you are currently connected as, choose the other option listed. It should chime in and let you access it from the my computer app on the desktop.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
  16. #16
    jamesgrenard's Avatar
    Posts
    Global Posts
    2 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jdub1981 View Post
    Thank you! This worked for me!
  1. HTC One S Jelly bean issue, not connecting to PC
    By Reekysporran in forum HTC One S
    Last Post: 08-22-2015, 12:10 PM
  2. GS3 just will NOT connect to PC..
    By cbass6411 in forum Sprint Galaxy S3
    Last Post: 11-27-2013, 09:20 PM
  3. Samsung galaxy note gallery not working
    By anon721037 in forum Introductions
    Last Post: 06-21-2013, 09:38 AM
  4. What bloatware on Samsung Galaxy Note 2 are safe to remove
    By K4Y in forum Samsung Galaxy Note 2
    Last Post: 03-01-2013, 09:41 PM
  5. HTC One S Jelly bean issue, not connecting to PC
    By Reekysporran in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-31-2012, 07:42 PM
