Results 1 to 6 of 6
    Thorin Oakenshield's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation what the hell kind of battery monitor is this i don't even
    it adds to 102% and it doesn't even list the other apps I use even after using it for a long time
  2. #2
    dodong27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: what the hell kind of battery monitor is this i don't even
    I believe once your full charge, all that will display is what's been used/active since after the full charge.
    From the looks of your pic above, it has been 18mins 34sec since it was full charge and all that's been used are the 3 subjects below...
    But don't set this in stone, I'm also learning the ways of the Android...
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dodong27 View Post
    "Screen" remains around 90% even after hours and hours of usage of different sorts of apps
  4. #4
    Gary02468's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MomPacksMyLunch View Post
    http://puu.sh/1JAhY
    Roundoff error can produce sums slightly above 100%. It's usual for the screen to dominate battery use, but other apps (and Android OS) ought to be listed too before very long. If not, something's wrong. (Are you running the stock OS, or did you flash a custom ROM?)
  5. #5
    lostchild's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I guess the % numbers always round UP. As for screen always at 90%, then you must set it at 100% brightness? Screen on mine is usually around 40%, but I set it to about 35% brightness. Try stream some radio for hours and have the screen off while doing that. You should see the screen % goes down.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It doesn't list at all.
    I'm running stock OS and I have already tried doing a factory reset to see if it fixes, but it doesn't still.
    - - - Updated - - -
    The brightness is on lowest and i have tried that still nothing
  1. THIS is the kind of battery HTC needs
    By Mike_is_Mike in forum Thunderbolt Accessories
    Last Post: 10-21-2011, 02:52 AM
  2. SGSII in Northern California - what the hell is going on?
    By holyevilcow in forum AT&T Galaxy S II
    Last Post: 10-04-2011, 06:30 PM
  3. Replies: 6
    Last Post: 05-05-2011, 04:07 PM
  4. What kind of battery life are you getting?
    By MissJennell in forum HTC EVO 4G
    Last Post: 02-01-2011, 09:41 PM
  5. What the hell is happening?
    By tmac9wr in forum Verizon Droid Incredible
    Last Post: 09-15-2010, 11:09 AM
