Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Like Tree3Likes
  1. #26
    MatroxD's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Another wifi issue !! SOLVED !!
    Yes, lol, good call!
    I have been doing networking/pc troubleshooting for years. It's, for me, one of those things just ingrained in my brain.
    The repeaters they have it now are great, as they work very easily and effectively. I almost recommend them by default for those that have multiple level homes or like going, for instance outside a lot. You just plug one in near the spot thats slow, or you "want"a clear signal, a Viola, never an issue again for that area period!
    A lot of times, unless you have an extremely large floorplan/square footage home, it will boost the signal on the entire floor(that is, if that is your goal). I love them, I just use one that is like a dummy router, as it allows me to run an external amplified antenna that boosts the signal even more.
    Sent from Note 2 via Tapatalk
  2. #27
    Megan Arlitz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah my dad took one of his old routers and turned it into a repeater. I should see if hes got another one he could do that with.
  3. Thread Author  Thread Author    #28
    Scott Kenyon's Avatar
    Posts
    Global Posts
    2,189 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    MoDaCo Switch Beta 8
    You can pick up an encore router on amazon for less than $30 that has repeater mode. I recommend them as I use them myself. Grab one of he can't hook you up.
    Sent from my SGH-I317 using Android Central Forums
  4. #29
    TheOtherBill's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Before you spend any money, get an app called Wifi Analyzer.
    Compare the signal strength in various parts of both houses, that should tell you if you need more hardware. And also check the channels you and the neighbors use. You can change that on your router if you need to.
    Scott Kenyon likes this.
  5. #30
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Alright thanks. :-).
  6. #31
    ItsaRaid's Avatar
    Posts
    Global Posts
    706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is there such a thing as a 4G/LTE mini cell?
  7. #32
    MatroxD's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I know the term sounds familiar, but I don't know what it exactly is.
    Is it referring to the portable devices that you can use to create a shared hotspot by taping into the wireless carriers network?
    If so, I have only witnessed one in use, and with the technology in these devices, unless you just have to host quite a few nodes (in this case portable), I would just use my phone? To be honest, I am not well versed in this type of communication. I had thought about purchasing one, just to tinker, but I just can't justify the expense within.
  8. #33
    Zyquan Howard's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a problem ever since a couple days ago my wifi has not been working on my phone. I click the wifi check box it says scanning for a little bit... & then it say "Unable To Scan For Networks" my router is perfectly fine. I need help.
  1. Another Problem/Issue
    By jasonrellis in forum Motorola Droid
    Last Post: 04-13-2010, 07:57 PM
  2. Wifi issues
    By WAM in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 03-06-2010, 06:22 PM
  3. Wifi issue after reset
    By Crowfoot in forum HTC Droid Eris
    Last Post: 03-02-2010, 04:01 PM
  4. Droid Eris WiFi Issue with Mixed Router Signals
    By ridavid81 in forum HTC Droid Eris
    Last Post: 01-02-2010, 10:09 PM
  5. WiFi Issues
    By VDubb22 in forum HTC Hero
    Last Post: 01-02-2010, 02:01 PM
