Another wifi issue !! SOLVED !!
Att note 2, rooted, running cleanrom att special edition. There is no att software installed on this handset.
I've had issues with wifi before on this phone, but now it works fine when tethers to my Galaxy Nexus. The tethered connection is secured with WPA2. My Home router is unsecured and I have no Internet access on it with my note. It seems to work for less than a minute, then nothing. Once in awhile it'll do something then back to nothing.
All the other devices work fine. I'm using my Nexus now on home wifi. Netflix is streaming on my Roku box in here, and on the PS3 in my bedroom. My laptop works great.
Keep wifi on during sleep is set to always, auto connect to att wifi is disabled. Check for service is disabled but seems to have no impact when enabled. Notification for open networks is off. Power saving mode is disabled.
I switched the router from channel 11 to 6, and that did nothing. The router only runs on 2.5ghz.
Any ideas on this? This is a deal breaker as I'm using Straight Talk, so I can't rely heavily on the mobile network.
Sent from my Galaxy Nexus using Android Central Forums.
If I have been helpful to you, please go to the store, buy a bunch of beer, and send it to my house.
1 Attachment(s)
Re: Another wifi issue !! SOLVED !!
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
Quote:
Okay I figured it out. With the note 2, you either need it protected or completely unprotected. You may not have an unsecured network with WPS available. If you do the note tells the router where to go.
If you plan on using your phone in an unprotected wifi network, go into the router settings and completely disable WPS. It'll work like a dream.
Big huge thanks to MatroxD for helping me reason this out. If you need anything buddy, give me a hollar.
Glad it worked out for you. That is interesting, but not completely unheard of.
But cool! As long as you got it worked out!
Sent from Note 2 via Tapatalk
Are we talking about the slowness of wifi on these devices? If so when I am at my parents house on there wifi I notice that its faster on my phone then it is at our house on our wifi. I believe we have the same settings on each network. My dad knows a lot and I had him look at ours here at the house, but it just doesn't make sense.
Could be a few things. His issue was connection period. Yours could be tweeks, emi, the router and it's antenna strength, if other things are slow, bandwidth, channel selection, etc. Could justbe the location of the router also. I hadto run a repeater simply becausei hada very consistent strength drop due to walls and thati can'trun my own router that hasa much stronger amplified antenna within it, versus their poj access point. Could be a lot of things. More info is required.
Ahh alright yeah my dad has a repeater as well. It could be the strength from the router. Good call. I do notice as well when I am up in my old bedroom its a little slower than where the repeater is. Good call I didnt think of that at all.
