Data-Battery usage Offending Apps on GN2
Does anyone know with regards to the apps that are Supplied Stock on the GN2, which are the ones that consume the most Battery / Data (Data Battery Hog) while open or running in the background. Any that potentialy prevent the device from going into a deep sleep.
Thank you in advance.
Re: Data-Battery usage Offending Apps on GN2
You mean like the Att Locker issue? If so, that one for sure.
The two I have found:
Att Locker
Att Messages
Sent from Note 2 via Tapatalk
AT&T Messages? Really? Darn, I really like that app and use it all the time. Haven't really noticed any battery drain, but I do tend to keep my phone plugged in when not using it.
