Factory Reset or Hard Reset Info
If you have to do either a Factory Reset or a Hard Reset on your Note2, doing so...will it restore to 4.1.2 or 4.1.1.?
I purchased the GN2 with 4.1.1 and upgraded to 4.1.2.
Also what is the method to ensure a total wipe and clean install of 4.1.2.
Thank you
Re: Factory Reset or Hard Reset Info
It will reset to 4.1.2. 4.1.1 no longer exists on your phone and has been replace by the the newer OS
Sent via Tapatalk
How do you wipe everything COMPLETELY and get a absolutely perfectly Clean Version of Yuppy Bean 4.1.2? AT&T.
If you're rooted and are running a ROM all you need to do is boot into recovery and factory wipe that way. Otherwise it's in the android settings under personal>factory reset on VZW model, not sure if it's different for att.
Sent from either my TF300 or VZW Note Dos. Boom! That just happened.
