Results 1 to 12 of 12
- 03-09-2013, 07:30 PM
Thread Author #1
Sub-par battery life
I've seen lots of battery life forums, and most of them show great battery life (over 12 hours) with lots of screen time. I'm not even in an LTE area, but I get very good signal. My screen brightness is at about 30% and I have two e-mail accounts (Exchange push and Gmail sync). My phone is about 4 months old, and this type of battery life has been typical.
My previous phone, an Infuse, could get nowhere near this, but I really think that the battery life on this phone can get better. What can I do to get more juice out of it?
Is this normal battery life? I really doubt it, but I want some feedback. Any help is appreciated. Thanks.
EDIT: The battery graph screenshot was taken after 26 minutes of minimal usage.Last edited by dlee1001; 03-09-2013 at 07:54 PM.
- 03-09-2013, 08:01 PM #2
Liked what I did or helped you out? A simple "thanks" would be great!
Samsung Intercept(retried), HTC Hero(retried), Motorola Atrix 2(game phone), Samsung Galaxy S3(main phone), Asus Nexus 7(better than my parents iPad) - 03-09-2013, 08:14 PM
Thread Author #3
Re: Sub-par battery life
N64oid doesn't drain as much battery as web browsing does. Web browsing makes my phone get warm and battery consumption can get up to 1.17A (that red number on the status bar). I've had other things on the status bar, such as the WeatherBug widget that was set to update every 15 minutes; I've turned that off and now I just open the app to see the weather.
3G Watchdog was originally set to update every 30 seconds, but now I have it to update every 15 minutes. The white numbers refer to the CPU clock speed in GHz, while the graph represents CPU usage. I don't think 3G Watchdog and the CPU widgets use that much battery, but what about Chrome? Is that a big battery hog? - 03-09-2013, 08:23 PM #4
I know browsing can do a number on my S3 if I'm using it a lot so depending on how much you are using it, it can. You don't see it on the stock battery graph but Samsung Push Service does a number. I have a post kinda explaining some tips on battery life. You can message me for more info and ideas if you like. There are countless things you can disable to get more life out of the phone (like S Voice if you don't use it)
Samsung Intercept(retried), HTC Hero(retried), Motorola Atrix 2(game phone), Samsung Galaxy S3(main phone), Asus Nexus 7(better than my parents iPad) - 03-09-2013, 08:34 PM
Thread Author #5
- 03-09-2013, 08:41 PM #6
From what i understand its for all of those Pre-loaded Samsung apps like ChatON and what ever else is pre-loaded. And it makes the battery life go down so fast is because the second there is a update or something it'll go straight to your phone. So say you got a email, instead of the phone waiting to sync every 15 minutes (or what ever time it is set to go) your phone will go off the second you get it on the email account. And for the S Voice, did you go in the app to disable it or go into the Application manger to disable it? I've also disable the Game Hub and Group Play and thinking on disabling some more later on
Samsung Intercept(retried), HTC Hero(retried), Motorola Atrix 2(game phone), Samsung Galaxy S3(main phone), Asus Nexus 7(better than my parents iPad) - 03-09-2013, 08:58 PM
Thread Author #7
Push Exchange e-mail and Gmail's real-time sync are musts for me. I disabled S Voice, ChatON, and various other pre-loaded apps in the application manager, so they don't even show up on my app drawer. I don't have Game Hub or Group Play on my phone.
What is your battery life like? Can you post a screenshot of it, including your screen time and awake times? If your battery life is better than mine, what else do you do to get that kind of battery life? - 03-09-2013, 09:13 PM #8
- 03-09-2013, 09:23 PM
Thread Author #9
- 03-09-2013, 09:33 PM #10
That's what I do as well. I also end the apps by just holding down the home key, I also have a and I just have the widget on my home screen and tap on it when ever i want to kill extra apps. Seems to have helped. Also go into maps and change the "report from this device" its what Google Now uses to update GPS and using data when ever it pleases. I noticed it has helped a lot since my data isnt loading up. Better then turning it all the way off- - - Updated - - -
And everything still works the sameLast edited by gotta have it android; 03-09-2013 at 09:49 PM.
Samsung Intercept(retried), HTC Hero(retried), Motorola Atrix 2(game phone), Samsung Galaxy S3(main phone), Asus Nexus 7(better than my parents iPad) - 03-10-2013, 01:17 PM #11
- 03-10-2013, 10:01 PM
Thread Author #12
Battery life terrible?
By bilobi in forum T-Mobile G1Replies: 20Last Post: 04-02-2013, 01:48 PM -
Samsung Moment battery life
By IIJBII in forum Samsung MomentReplies: 97Last Post: 03-21-2012, 08:48 PM -
Improving Battery Life on Your Android Device
By ERDude in forum HTC HeroReplies: 32Last Post: 02-04-2010, 12:33 PM -
battery life
By kunak83 in forum Motorola DroidReplies: 42Last Post: 11-29-2009, 11:28 AM -
Anyone's Battery Life Getting BETTER?
By Christopher in forum Motorola DroidReplies: 28Last Post: 11-20-2009, 11:04 PM
Reply
