1. Trevor Barton's Avatar
    Hey folks. Funny how problems often bring the first post.
    I have a challenge. It seems like my "screen usage" is attributing to my battery drain a great deal even though my brightness is at 50% and I have all the power save features enabled. I'm going on hour 11 here and I'm cutting below 40%. When I check the usage, it seems to directly correlate with awake time. I have disabled my motion controls as a result.
    I'm super happy with my phone! I know I've been handling it a lot..I'm not confident I've spent 40+% of it's on-time handling/using the phone (4 hours in the last 10 :| )
    I'm syncing a bit too, but I didn't feel syncing equated to screen-on time.
    Here's the shots. Any thoughts?
    Attached Thumbnails Screen Usage and high battery drain-screenshots_2013-03-20-21-22-10.png   Screen Usage and high battery drain-screenshots_2013-03-20-21-22-27.png   Screen Usage and high battery drain-screenshots_2013-03-20-21-22-37.png
    03-20-2013 11:43 PM
  2. Trevor Barton's Avatar
    I've done some reading and most people agree ~5 hours screen-on time is what you can expect from a Note 2. This is agreeable. I think I'll try...(operative word here is try <3) to put my phone down after a full charge all day tomorrow...and see if I still get drainage for screen activity. If I have actually been actively using this thing for nearly 50% of my day, then my gawsh I need to settle down!
    03-21-2013 12:20 AM
  3. Bajanbox's Avatar
    yeah your getting average use! With those numbers. But if you can't seem to find yourself to put it down:thumbup:. I recommend a extended battery!
    Here's a link to one.. :thumbup: http://www.amazon.com/gp/aw/d/B00A6U...cUvbUpU2656796
    Sent from my SAMSUNG-SGH-I317 using Xparent SkyBlue Tapatalk 2
    Trevor Barton likes this.
    03-21-2013 02:16 AM
  4. Dreamliner330's Avatar
    Here's a link to one.. :thumbup: http://www.amazon.com/gp/aw/d/B00A6U...cUvbUpU2656802
    Just wish there were some extended battery friendly cases....
    03-21-2013 02:26 AM
  5. Bajanbox's Avatar
    They are out already!! :thumbup:
    http://www.amazon.com/gp/aw/d/B00ANU...cUvbUpU2656804
    03-21-2013 02:29 AM
  6. Trevor Barton's Avatar
    Haha thanks for the tips folks. Yeah I'm pretty sure I've just totally lost track of time while using my new favourite toy! Kind of a useless reason to start a thread until you started making useful suggestions for new phone fiends like me. I really should settle down eventually. If I don't, I know where to shop ^_^
    Bajanbox likes this.
    03-21-2013 02:47 AM
  7. BeRich's Avatar
    There is a drastic change in battery life on my end between using my screen all day at 100% brightness vs the lowest setting. I'm not talking just a couple of hours, either. I'm not rooted on this replacement yet and there was one day this week where I was outside and had to have the screen brighter. I was using it like how I normally would. BIG mistake. My phone was almost dead before the day ended, which I have yet to see
    03-21-2013 04:36 PM
  8. jdub1981's Avatar
    I get on average about 7-8 hours of screen on time. Prior to 4.1.2 it was getting 10-12 hours. Most of the time its only for low rez games and internet browsing. So if you are playing something thats ramps up cpu/gpu speeds you can expect less
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    03-22-2013 08:44 AM
  9. Bajanbox's Avatar
    +1:thumbup:
    03-22-2013 11:23 PM
  1. 'Screen Adjuster' and S3 battery life
    By hossman12 in forum Samsung Galaxy S3
    Last Post: 12-25-2012, 01:50 AM
  2. Maps 5.8 - high battery drain
    By mrg666 in forum Android Apps
    Last Post: 08-01-2011, 08:38 PM
  3. High battery drain for no reason
    By d1ez3 in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 06-16-2011, 07:35 PM
  4. Handcent LED light and Excessive Battery drain?
    By dequardo#AC in forum Verizon HTC Thunderbolt
    Last Post: 03-25-2011, 06:36 AM
  5. Screen/backlight stays on...battery drained.
    By rick16 in forum Motorola Droid X
    Last Post: 11-15-2010, 06:19 PM
