Results 1 to 7 of 7
    TaylorFC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Problems with Note 2 & S4
    So my wife got her S4 on Thursday and I am having trouble getting Group Play to work between her S4 and my Note 2.When she starts it, I can see the Group Play session, but when I type in the password she set the 'connect' button is grayed out and won't let me select it. When I start it, she doesn't see a Group Play session (the name of my session is the same as my Wi-Fi network).
    Also, we are having trouble setting up a WiFi direct connection.
    Are these issues because the Note 2 has not been upgraded to 4.2.2?
  2. #2
    lilwhiteguy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Problems with Note 2 & S4
    I believe group play is for the s4 only (as of right now)
    Sent from my SGH-M919 using Tapatalk 4 Beta
  3. #3
    mmohn01's Avatar
    Posts
    Global Posts
    390 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lilwhiteguy View Post
    I believe you are right. I think it's coming to more phones with the Key Lime Pie update.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    lilwhiteguy likes this.
    TaylorFC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So what good is the Group Play I have on the Note 2? Will it only work with other Note 2's?
  5. #5
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It should work when the note 2 gets updated to touchwiz 4.2.2, like on the s4.
    TaylorFC likes this.
  6. #6
    jdub1981's Avatar
    Posts
    Global Posts
    1,386 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ATT SE 1.0
    Allshare play is not the same as group play as far as I know.... weird I do not have a group play app on my note 2.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
  7. #7
    scott750's Avatar
    Posts
    Global Posts
    226 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Rom / Non-Rooted
    Im having the same issue too. The passwords betwwen the S4 and Note 2 have different criteria. The S4 uses up to 6 numeric digits, while the Note 2 wants minimum 8 alphanumeric characters. I was told the Note 2 and S4 versions are different, even tho they both are running the same version number. I was also told that the Note 2 will be updated soon to okay with the S4.
    On a side note, how do I get more games for Group Play? I only have 1 game so far. I downloaded some games fr9m Google play and Samsung Apps that say group play, but they arent showing up in my list.
    Sent from my SAMSUNG-SGH-I527 using Tapatalk 2
  1. Bluetooth vehicle problem with Note 2
    By KMF0727 in forum Verizon Galaxy Note 2
    Last Post: 09-03-2013, 05:13 AM
  2. Problems with my new S4- bluetooth and lockscreen
    By seaela in forum Samsung Galaxy S4
    Last Post: 08-18-2013, 10:50 AM
  3. Problems with ATT and the Galaxy Note
    By mavrrick in forum AT&T Galaxy Note
    Last Post: 03-18-2013, 06:06 PM
  4. Had couple problems with note 2
    By willie51 in forum AT&T Galaxy Note 2
    Last Post: 12-23-2012, 07:54 PM
  5. Problems with note 2
    By Hernandezsrt in forum Samsung Galaxy Note 2
    Last Post: 12-14-2012, 07:34 AM
