Results 1 to 8 of 8
    pinknail's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default AT&T Note 2 - My MMS & Text Msgs Will Not Send.Well....l
    I have had no complaints for a year and a half with my Note 2, however last week I started getting the old "failed" message from my server when I would send a text or a MMS message. Do I have something set wrong? Keep in mind Im not quite as tech savvy as the rest of you seem to be. Thank you for any advice. And by the way, Ive been to ATT once, and they replaced the sim card thinking that was the issue, and yesterday I spent several hours on the phone with a technician. No help.
  2. #2
    TJB
    TJB is offline
    TJB's Avatar
    Posts
    Global Posts
    184 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: AT&T Note 2 - My MMS & Text Msgs Will Not Send.Well....l
    Same issue with me. I have text messages that keep failing to send. Is there a fix for this?
  3. #3
    mrscaston30's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think I found a solution. For a couple days now I wasn't able to send and receive MMS messages but I was able to get regular messages. I am using goSMS to send and receive messages and I switched back to the stock app and still had issues so I searched and searched and I think I found a solution that might work for your problem as well. Try this and see if it works: Go to settings, more settings, mobile networks, access point names, and once in there you should see something that says ATT Phone and a green dot on the right hand side, click on the left soft key at the bottom and click on reset to default. Once you do that, you can either restart your phone or try it without restarting but go back into your text messages and try sending one out and see if that helps.
  4. #4
    Keith Go Packers Boror's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having this same problem today. I tried the settings option and it didn't work. still searching the web for answers. Thank you for the help.
  5. #5
    1980tammyririe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Glad I'm not the only one with this issue today.
  6. #6
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just removed hangouts and my message went thru I'm waiting for confirmation.
    ( It worked )
  7. #7
    comk4ver's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tried Google hangouts and it's not working.
    Sent from my VS980 4G using Tapatalk
  8. #8
    Don Tucker1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tried it, didn't work for me.
  1. Verizon HTC One - Missing my clock
    By Mono4411 in forum Verizon HTC One
    Last Post: 12-07-2013, 08:58 PM
  2. i cant adjust my volume on my Galaxy S4 OctaCore
    By Vinoth Obroi in forum Samsung Galaxy S4
    Last Post: 10-01-2013, 11:02 PM
  3. Best Buy trade in value for note 2 just dropped
    By MannyZ28 in forum Samsung Galaxy Note 3
    Last Post: 10-01-2013, 09:15 PM
  4. What features does the note 3 have like the S4? Hardware??
    By icellphones32 in forum Samsung Galaxy Note 3
    Last Post: 10-01-2013, 08:54 PM
