1. ska916jedi's Avatar
    Will the N3 battery fit in our N2? If so is there a way to order one? Thanks
    10-19-2013 08:35 PM
  2. srkmagnus's Avatar
    No. Are you trying to get a replacement or something with a larger battery capacity? Check the ShopAndroid - #1 Store for Android Accessories site for a replacement battery that fits the Note 2.
    ska916jedi and tube517 like this.
    10-19-2013 08:52 PM
  3. ska916jedi's Avatar
    A bigger battery. Have you tried one? Any you suggest?
    10-19-2013 09:41 PM
  4. DesElms's Avatar
    You can go up to around 3900mAh with batteries that are the same size as the Note II's stock 3100mAh battery; however, if you want to jump up to like 6500mAh or 9300mAh, then you'll need an oversized battery, and a whole new back cover to accommodate it.
    Brands like RAV, ZeroLemon, Hyperion, QCell, Onite and others are all fine. Just look for them on Amazon, and you'll see a wide range of prices. Look, also, on Youtube for videos which both explain and review them.
    10-25-2013 03:01 AM
  5. Shelter7's Avatar
    I can recommed Zerolemon being a reliable external battery brand, yet affordable. Naturally you can try other brands, to convince yourself
    tube517 likes this.
    02-19-2014 02:23 PM
  6. tube517's Avatar
    I've read ZeroLemon is the one to get.
    02-21-2014 06:58 PM
  7. Shelter7's Avatar
    Indeed, you can say so
    Comparing with other brands, it lasts more. In my case, it`s about 2h extra, during an intense cycle of use (wifi, video calls).
    In addition you can test it for 180 days, to see if it`s what you need
    tube517 likes this.
    02-22-2014 04:02 PM
  8. Matt Behnken's Avatar
    I bought the extra battery and charger kit from best buy for $27. I'm a heavy user and I switch the batteries out regularly.
    02-25-2014 01:48 AM
  9. Shelter7's Avatar
    If it`s Zerolemon, that you bought, expect the best performance ever It can last even for five days, used at full throttle
    Matt Behnken likes this.
    02-25-2014 12:21 PM
  10. tube517's Avatar
    Zerolemon for $27???? I'd like to see where that is?
    02-26-2014 06:57 PM
  11. mtech5's Avatar
    Zerolemon is the way to go. I have one with the rugged case and love it. I usually get 2 1/2 to 3 days with over 9 hrs of screen time.
    tube517 likes this.
    04-22-2014 12:18 AM
  1. Unlock bootloaders for note 3
    By mobclan2013 in forum General News & Discussion
    Last Post: 05-03-2015, 02:56 PM
  2. Best Extended Battery?
    By DRILLINDK in forum Samsung Galaxy Note 3
    Last Post: 10-21-2013, 12:09 AM
  3. going too sell my laptop and get the smasung note 10.1 2014
    By snowboarders in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 10-20-2013, 01:31 PM
  4. Launcher Pro on Note 3, do you give anything up?
    By dss2000 in forum Samsung Galaxy Note 3
    Last Post: 10-19-2013, 05:36 PM
  5. Samsung Galaxy S4 - Tasker question: How to read/write the external SD card?
    By BillDennes in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 10-19-2013, 05:08 PM
