Hey guys I upgrade my fiance's Note 2 on AT&T to Android 4.3 via OTA update since the said update has been applied she has had major signal loss and pretty much no cell reception and comes in and out and its not stable any ideas? is there a way to perform a factory of factory reset via Odin? I've done a factory reset in the settings, but the same problem still exists. Or should I root the phone and reinstall the stock firmware I'm thinking that it's the radio that was a bad flash during the OTA.
