Qi wireless charging systems
gzbsds
55
Has anyone have any experience with the Qi wireless charging systems? I tried it with my Note 2 and it dosen't seem to charge.
zrxoa1
1,403
44
No one?? I have wireless charging pads all over the house... Nexus 5, HTC 8x, converted S3... Now I have switched my wife to ATT version of the Note 2 and I want to convert her phone. So I have same question...
Also curious about best receiver for the Note 2. The one in the S3 is a bit bulky.
Sent from my Nexus 5 using Tapatalk
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
The Samsung one would perform the best and run the coolest.
There are pads from third parties that you put between the battery and door, if bulk is the primary concern.
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
zrxoa1
1,403
44
Yeah, I have one of those pads in my S3....makes a high point in the back... Phone will spin like a top. Lol. I put it in a LifeProof case and it charges fine.
Sent from my Nexus 7 using Tapatalk
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Yeah it does bulge where the pad is a little bit but most cases should fit
buchrob
Knuckles rapped previously, so not allowed to include outside links. I can't tell directly you which one to avoid.
One point to make: large capacity battery on Note 2 will need much more oomph than the typical unbranded Chinese wireless charger can supply. Laws of electricity reign: current will flow from high voltage to low. The unit I had actually would drain a full battery. Supplier was gracious and refunded.
I would have been happy with a slow charge to avoid putting stress on the charging connection, but it was not to be.
Laila Nance
