10-06-2012 06:57 AM
26 12
tools
  1. waynezo's Avatar
    Do they make Android earbuds with mic play/pause and vol control?
    I have a set of vmoda with apple controls. Is there software to make them work with Android?
    02-21-2012 06:36 AM
  2. Kevin OQuinn's Avatar
    You might have to get one of those fancy headsets that has an app available. I don't think there's a standard for inline controls for Android, which is why there aren't a ton of headsets with these controls built in.
    waynezo likes this.
    02-21-2012 09:13 AM
  3. daddybigas's Avatar
    Yeah, I was a little bummed when I opened my box and there was no headset. I figured I would get a cheap set with controls. If I keep the Note I will just grab a set online (assuming Android phones support controls on headphones).
    waynezo likes this.
    02-22-2012 07:44 AM
  4. PaulF's Avatar
    Anyone try this: Amazon.com: Samsung HM3700 Stereo Bluetooth Wireless Headset: Cell Phones & Accessories
    It seems cheaper than just a good set of earbuds and is wireless bluetooth.
    Samsung HM3700 Review & Rating | PCMag.com
    waynezo and Reaper69 like this.
    02-22-2012 08:10 PM
  5. waynezo's Avatar
    This looks like a winner. It doesn't have media player controls except volume, but there may be a voice control app for Android.
    Any thoughts?
    02-23-2012 05:07 AM
  6. jlrera's Avatar
    Image S4A Headphones for Android you could probably get em cheaper on amazon or ebay.
    02-23-2012 08:16 AM
  7. planoman's Avatar
    The vmoda's work fine on android at least the Samsung phones. You can pause and skip song using the controls. I used mine all the time. Also talk with them if I have them on and get a phone call.
    02-24-2012 04:50 PM
  8. darthmemnoch's Avatar
    Ordered these myself and so far so good. $24.50 from amazon. The sound quality on he headset seemed slightly too bassy but he headphones sound great. Comes with several earpices and adapters and an AC charger. There is a Samsung bt app that has terrible reviews but so far I've had no issue with it.
    Of course I have NOT made any calls from a noisy/windy area or car. So take it for what its worth.
    sent from a gigantic phone
    PaulF likes this.
    02-25-2012 06:48 PM
  9. waynezo's Avatar
    Were you able to control a media player with it? Volume next song, pause play, etc.
    02-26-2012 04:32 AM
  10. darthmemnoch's Avatar
    No. There are no media controls besides volume. There might be voice command prompts if you press the talk button but I didn't try it.
    waynezo likes this.
    02-26-2012 09:10 AM
  11. waynezo's Avatar
    Thanks I want this item but I really need those media controls
    02-26-2012 09:58 AM
  12. waynezo's Avatar
    https://market.android.com/details?i...=search_result
    Found this app works great with my vmoda remix earbuds for media controls. Mic doesn't work maybee there is an app for that too.
    Anybody try these?
    http://www.amazon.com/Samsung-EHS60-...cUvbUpU1630947
    02-28-2012 04:34 PM
  13. JtothaR's Avatar
    Apple controls have always worked on android for me. One click = Play/Pause, Two Click = Skip Forward, Three click = Skip back. Don't know why this doesnt work for you guys...
    03-01-2012 12:05 PM
  14. shansmi's Avatar
    there is a klipsh set for Android that has what you areooking but they cost $100.
    03-07-2012 10:18 PM
  15. GALAXYNOTE9394's Avatar
    You would think a high end phone like my Galaxy Note would come with a pair of eaebuds, with all controlls. Maybe there will be some to come out for it before long.
    03-13-2012 07:59 AM
  16. jess.hickey's Avatar
    Headset controller in the market works with iphone style headsets. You only have function from the middle button but you can set it for single/double/triple/quad clicks + clicks and hold.. Can even set it to run volume up and down from the middle button. Free and quite good in my opinion...works flawlessly with my beats.
    03-14-2012 06:33 AM
  17. mastermixer99's Avatar
    The controls work fine, but I think people want the mic to work too, which I believe it does not with the apple earbuds.
    03-14-2012 10:30 AM
  18. JtothaR's Avatar
    I answer calls at work on mine and the mic works perfectly.
    Oh and to the guy above, the note comes with a set of headphones with controls. Maybe they forgot yours?
    03-25-2012 05:12 PM
  19. daihard2008's Avatar
    I just tried my wife's iPhone earbuds with my Galaxy Nexus. The only controls that work are (1) Single clicking the centre button to play/pause, and (2) Double-clicking the centre button to skip. The following controls don't work.
    * Triple-clicking the centre button to go back to the beginning of the current track
    * Volume up/down controls
    I can forego the triple click, but it drives me mad to not be able to use the volume control of my headphones. That's one of the very few things I miss on Android...
    04-23-2012 11:19 PM
  20. trumpetdude88's Avatar
    My wife got a Note and it did not come with a headset either.
    04-24-2012 01:08 PM
  21. kimtyson's Avatar
    AT&T Note does not come with earphones\headset. Some Notes do and some don't.
    04-24-2012 07:42 PM
  22. chrgnthru's Avatar
    The Klipsch someone previously linked are about the best ear buds you can get in terms of sound quality. It designed with Android in mind so it will work. I can also confirm the iBeats work as well, even the mic.
    04-25-2012 11:38 PM
  23. daihard2008's Avatar
    Just tried a pair of Motorola S305s with my GNex. It must be the BT capability - the volume control on the headphones works perfectly!
    04-26-2012 09:17 AM
  24. PaulF's Avatar
    I found out something about the HM3700 Bluetooth headset this morning. I have been using the included 3.5 head phone adapter to turn my old PC speakers into Bluetooth speakers. I found out that if you leave it connected when you go to sleep it can make the wakeup alarm very very loud. :-)
    Sent from my SAMSUNG-SGH-I717 using Android Central Forums
    06-08-2012 02:33 AM
  25. ruebourbon99's Avatar
    I bought these earphones and they work fairly well with my phone but they are incredibly difficult to keep in my ears. They have three buttons but none of them control volume. The basic track functions also work with google cloud music and slacker radio. They can also call the last person in your call list with a double click of the middle button (except if using winamp). I'm no audiophile but I think the sound quality is pretty good too, with good range and a decent amount of base. They even have an extra wire in the cord specifically for the fm antennae. But I must repeat, they are super hard to keep in my ears due to the way they are designed.
    HTC Wired Tangle Free Stereo Headset - White
    Also just go to ebay or amazon and type in HTC RC E190 and they will pop up.
    10-05-2012 01:30 PM
26 12
