Results 1 to 11 of 11
    Default sync is currently experiencing problems ERROR
    I'm new to the forum but I hope someone can help me :0) I started getting this error "sync is currently experiencing problems. it will be back shortly" on my Samsung Note about 2 days ago. I've tried everything even the dreaded system reset. Ugggh any help would be great. Everything was working great and this just happened out of the blue. I'm stumped.
    I would appreciate any help..
    Last edited by Rlg4444; 02-25-2012 at 08:05 PM. Reason: change title in hopes I get a response
  2. #2
    npyle's Avatar
    Posts
    Global Posts
    213 Global Posts
    Default Re: sync is currently experiencing problems ERROR
    Is it only with the Twitter contacts sync? All my other accoutns sync properly--including non-contact stuff from Twitter. It's only the contact sync. In reading some other forum posts, looks like it's a wide spread Twitter for Android probably--not just on the Note.
    Thank you for your response. I uninstalled Twitter and Facebook before I did my factory reset and I'm still having issues. 70% of my contacts have synced to my phone but not the rest and they also are not updating when I make changes.
  4. #4
    Kevin O'Quinn's Avatar
    Posts
    Global Posts
    7,708 Global Posts
    ROM
    Stock
    So you did a factory data reset and the problem still exists? That's really strange, honestly. I've had that error before but a simple restart fixed it.
    Try only syncing one thing at a time. Like calendar, then contacts, and see if you only get the error with one of them, or all of them.
    Forum Rules & Guidelines -- CLICK HERE
    I'm an NVIDIA Tegra Champ. Here's what that means. It means that from time to time I might receive products and/or services from NVIDIA to evaluate them and provide feedback to NVIDIA and you, our valuable members. What this does NOT mean is that my opinion will be biased. Any opinion that I express here and elsewhere are solely based on my personal preference and any relevant expertise that I may/may not have on the subject matter.
    Now all my calendar entries are not syncing. I know it's not my phone because I have another Droid X on Verizon and I'm having the same thing is happening.. Uggh. I'll probably get hate responses but thank god for my Iphone or I wouldn't have my contacts or calendar synced at all.
  6. #6
    any solutions, my contacts have not synced since april? still getting the sync having problems, it will be back shortly
  7. #7
    I was having the same issue. This is what resolved the problem for me.
    Go to "Settings". Select "Applications".
    Select "Manage Applications".
    Scroll down to "Contacts Storage"
    Click on "Clear Data"
    Go back to to "Settings" again and in "Data Synchronization"
    resync by pressing "Synchronize Now"
    Thanked by:
    wcd350
  8. #8
    thanks, that seemed to work for me also
  9. #9
    I know this is a little old, and I do not have the tablet, I have a samsung galaxy s2, but I thought I would share my experience with this error.
    my particular error came from the contacts not syncing. Everything else would sync fine. It turns out that, so far to date, it was because I was adding phone numbers and contacts through a third party contact application. In this case, it was "go contacts".
    when I added a contact through the native contacts application, everything would sync fine. As of today that is still holding true. so feel free to pass the info along to anyone who may be experiencing similar problem, perhaps this may be of help to them.
    Larry
  10. #10
    My problem was with skype, I removed it and my tablet 10.1 syncs
  11. #11
    Recently I began using Google's 2-step verification security for my phone. I had no idea it was causing sync problems until I back tracked everything I did with my phone. So I turned of the 2-step verification and my Google Voice started syncing again.
