Results 1 to 4 of 4
    Default Note Battery Replacement
    Hey guys,
    I ordered an extended battery for my note off of ebay to hopefully get a few more hours out of it, but just noticed that it says it is for the International version and I have the ATT version. Do they both take the same battery regardless? It will suck if I have to order another battery.
    Thanks!
  2. #2
    Default Re: Note Battery Replacement
    I think that the battery is the same but the back cover attaches differently.
    Alright thanks! I guess I will just have to wait and see to know for sure.
  4. #4
    CRJDRIVER's Avatar
    Posts
    Global Posts
    115 Global Posts
    so did the battery work?
