I wanted to share with my fellow runners that if you are looking for a running solution to enable you to carry the Note on your run, I found that the Incipio Featherlite Case works really well, since it's so thin and adds no bulk, you don't have to remove it for it to fit into the armband.
Below are links to the actual case & armband I use.
http://www.amazon.com/Incipio-Samsu...ag=hawk-future-20&ascsubtag=UUacUvbUpU1745836
http://www.amazon.com/BW-Neoprene-E...ag=hawk-future-20&ascsubtag=UUacUvbUpU1745836
