Results 1 to 6 of 6
    Default Note 4g lte signal
    I am looking to purchase one but i need some opinions on the signal. Other opinions also wanted.
    Sent from my ATRIX 4g using Tapatalk
  2. #2
    Default Re: Note 4g lte signal
    coming from an atrix i find signal to be the same. Maybe a bit better. Of course lte is way faster than the 4g (hspa+) the atrix runs on. So depending where you are your signal will be the same and if your in lte coverage you will get lte.
    Default
    Its about the same signal but the speeds are dam! on the note
    Sent from my Samsung Galaxy Note 4g LTE using Tapatalk 2
  4. #4
    Default
    In Queens NY, I actually hit 50 mbs on LTE. Hows that for ya!!?
    Sent from my SAMSUNG-SGH-I717 using Android Central Forums
  5. #5
    AzD
    AzD is offline
    AzD's Avatar
    Posts
    Global Posts
    221 Global Posts
    Default
    Sent from my Galaxy Note
  6. #6
    mmohn01's Avatar
    Posts
    Global Posts
    390 Global Posts
    Default
    I hit 62mb before LTE was officially launched. After launch I consistently get 30mb down and 9-10mb up.
