Results 1 to 4 of 4
    tstens22's Avatar
    Posts
    Global Posts
    13 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy note battery
    Can you use a note 2 battery in an original note. Just curious I am in the market for a new battery, my upgrade it's not for awhile.
    Thanks
    Sent from my SAMSUNG-SGH-I717 using Android Central Forums
  2. #2
    J HighNote's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy note battery
    No, they aren't compatible. Try checking for hyperion batteries for the Note with a charger. I found this on Amazon, they have the battery here: Amazon.com: Hyperion Samsung Galaxy Note 2600mAh Battery: Cell Phones & Accessories and the charger here: Amazon.com: Hyperion Universal Rapid Battery Charger for Samsung Galaxy S3, Samsung Galaxy Note, Samsung Galaxy S Blaze 4G, Samsung Galaxy S II, and Samusung Galaxy S II Skyrocket (Compatible with Most Samsung Android Phones): Cell Phones & Access When I got mine, it was a set of the charger and two batteries. It works very well.
  3. #3
    gigigia's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How long did you guys have the phone before you had to change battery ? My note started last week to discharge fully in 3 or 4 hours, w
    ithout even using it...it could be that I have to replace the battery already after a year of use?
  4. #4
    J HighNote's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gigigia View Post
    I swap out batteries occasionally so I don't know how long one would last. However, I had a similar issue when I was trying to figure out how to sync Snotes. I had every storage site, weather, gps, etc. all set to sync often. So even when I turned the screen off, the battery would drain like a rocket because it was all running in the background. If you don't have a bunch of things running like that, it might be worth the ten dollars or so to try a new battery. I can vouch for the Hyperion brand, it's worked as well as the one from Samsung.
    gigigia likes this.
  1. Galaxy Note 2 Battery Life Review (After 2 Weeks)
    By Lucidmike in forum Samsung Galaxy Note 2
    Last Post: 01-25-2013, 06:44 AM
  2. AT&T Galaxy Note Case for extended battery
    By Makaveli671 in forum AT&T Galaxy Note
    Last Post: 06-01-2012, 07:56 AM
  3. Galaxy S3 & Galaxy note battery
    By droid83 in forum Samsung Galaxy S3
    Last Post: 05-30-2012, 05:17 PM
  4. Galaxy Note Accessories!(OEM pouch/car docks/spare battery pack)
    By robstunner in forum Marketplace Archive
    Last Post: 03-08-2012, 10:05 AM
  5. Galaxy Tab Battery Life - Pretty Darn Good
    By zmetl in forum Samsung Galaxy Tab
    Last Post: 11-07-2010, 05:36 PM
