Results 1 to 4 of 4
    Default Need help ASAP GALAXY NOTE SYSTEM PROBLEM
    i have the galaxy note for att and when i turn it on it will vibrate and turn off and when i try turning it back it will vibrate and the screen will be black .... has any one had this problem with there if so can some one plz help me
  2. #2
    Default Re: Need help ASAP GALAXY NOTE SYSTEM PROBLEM
    Try turning it of and on, same happened to me
    Sent from my SAMSUNG-SGH-I717 using Android Central Forums
    i did that what it does is that it will boot up correct but when it gets to the att intro it will shut off and vibrate while the screen is black
  4. #4
    randall2580's Avatar
    Posts
    Global Posts
    945 Global Posts
    ROM
    GNote ICS, GNex JB
    Markus I assume you haven't rooted or ROM'd your phone?
  1. New stupid problem... Need help asap!
    By Mcook1999 in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 04-27-2011, 08:13 AM
  2. Need help ASAP!!!!
    By rvcafighter in forum Verizon Droid Incredible
    Last Post: 11-16-2010, 05:48 PM
  3. need help asap
    By larod213 in forum AT&T Captivate Rooting, ROMs, and Hacks
    Last Post: 11-08-2010, 10:05 PM
  4. Need Help (No not a froyo problem)
    By irock1985 in forum HTC EVO 4G
    Last Post: 07-31-2010, 01:23 PM
  5. need HELP...ASAP
    By AuxiliaryPie in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 04-24-2010, 06:38 AM
