Results 1 to 3 of 3
    Question Help with Galaxy Note battery and yiboyuan universal battery charger ?
    Hello there.
    I just purchased a new battery and it came with the yiboyuan universal battery charger.
    According to most posts, it's supposed to be red while charging, and blue when fully charged.
    However, when I plugged my uncharged battery in, the light turned blue, not red.
    I know for sure it's not fully charged because I just took it out of my phone and it was at 30%.
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,733 Global Posts
    ROM
    Stock for now
    Default Re: Help with Galaxy Note battery and yiboyuan universal battery charger ?
    Quote Originally Posted by jaenixlee View Post
    Hello there.
    Try stock charger and cable
    From my Galaxy Note 2 via Tapatalk
    If i've made life easier buy me a Macchiato
  3. #3
    When you put the battery in (unplugged) it turns blue, then you know it is in right. Plug it in, and it turns red. When it is done, it turns purple. It is weird, but works, especially if you have a second battery and want to charge one while you use the other.
  1. Replies: 7
    Last Post: 12-24-2012, 09:47 AM
  2. Newbe needs help with screen time out and lock
    By pianomanss87 in forum Verizon Droid Incredible 2
    Last Post: 06-25-2011, 06:45 PM
  3. Replies: 7
    Last Post: 11-02-2010, 02:45 PM
  4. help with fios remote app and volume
    By rjdangerous in forum Android Applications
    Last Post: 10-15-2010, 07:45 PM
  5. Need help with emailing on phone and outlookexpress
    By tmax1964 in forum Motorola Droid X
    Last Post: 08-05-2010, 09:10 PM
