1. Jozilyn Muniz's Avatar
    I flashed clockwordmod recovery using Odin but the superuser file I downloaded isn't working for 4.1.2. I tried this one Superuser-i717-ICS-signed.zip, Installs Superuser 3.0.7 and su 3.0.3.2.
    I can access clockworkmod recovery, but when I turn on my device I keep getting error messages when using ROM manager or Superuser app.
    Where can I find a compatible superuser file?
    06-24-2013 08:52 PM
  2. Scott Kenyon's Avatar
    This has happened to me with Superuser in the past. The best thing you can try is to install SuperSU instead of Superuser. It worked much better for me, and got rid of my errors. Grab it in the Play Store. There will be directions on how to swap them that work perfectly in the app description.
    06-24-2013 10:30 PM
  3. tube517's Avatar
    06-24-2013 10:32 PM
  4. Golfdriver97's Avatar
    I agree to get SuperSU. Since you have root access it shouldn't be a big deal. Download, open, grant superuser access, and then disable your old superuser app.
    Jozilyn Muniz likes this.
    06-24-2013 10:44 PM
  5. Jozilyn Muniz's Avatar
    Thanks! Problem solved.
    Scott Kenyon and tube517 like this.
    06-25-2013 02:03 AM
  6. Golfdriver97's Avatar
    Awesome!!!
    Glad you got it fixed.
    06-25-2013 09:42 AM
  1. No Superuser access after ICS RUU
    By orgelbau in forum Rezound Rooting, ROMs, and Hacks
    Last Post: 08-10-2012, 10:27 AM
  2. Handcent requesting superuser access?
    By menschmaschine5 in forum Android Apps
    Last Post: 01-12-2012, 11:41 AM
  3. After Verizon update Superuser does not work, I need help!
    By tsramek in forum Verizon Fascinate
    Last Post: 12-13-2011, 09:02 PM
  4. How Do I Gain Root Access Running EB01?
    By mr flannery77 in forum Verizon Fascinate
    Last Post: 08-31-2011, 09:43 PM
  5. Can't access my Text messages anymore..Help?
    By Northstar_69 in forum Verizon Droid Incredible
    Last Post: 09-18-2010, 10:08 PM
