1. Donald Bough's Avatar
    I received a Galaxy Note 1 I717 (AT&T) and it was in a bootloop. I have experience with flashing stock roms through Odin and fixing bootloops that way. So after going through recovery mode, wiping, flashing, I am still getting put into a bootloop after a successful flash on Odin. I've spent 2 days with this and tried all the little suggestions of wiping before flashing, using the original roms from XDA , trying some other stock roms specifically for my model and I'm still left with a bootloop. I'm capable of getting into download and recovery, and I've actually gotten different stock recovery modes! So the flashes are working, but it just won't boot up correctly. I looked around for the U.S. version of the Pit CSC Phone and PDA to try and re partition it, but they are absolutely NOWHERE! Any help would be greatly appreciated, whether it's a ROM suggestion, the re partition files, or whatever else.
    11-15-2013 02:32 PM
  2. Javier Cheddar's Avatar
    Where you able to fix the issue? I've been struggling with my i717 tried so many roms if i don't get the bootloop in the "optimizing apps" i get it on the configuration
    12-28-2013 04:20 PM
  3. Donald Bough's Avatar
    I couldn't find any solution to it. I had my buddy look at it to and he couldn't find anything to it either, our problem might have been hardware.
    12-30-2013 11:01 AM
  4. tube517's Avatar
    Might be a stuck power button. It's a common issue on the i717
    Donald Bough likes this.
    01-01-2014 09:46 PM
  5. Donald Bough's Avatar
    How would I go about fixing something like that?
    01-02-2014 04:02 PM
  6. tube517's Avatar
    broken power button? - xda-developers
    This thread may help. I don't have the issue but something here may help. Good luck!
    01-04-2014 11:17 PM
  1. HTC One Bricked While Flashing ROM, No Back Up, No RUU
    By veddar83 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 07-01-2014, 10:56 AM
  2. Adobe Flash
    By BKVic in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-23-2013, 10:43 AM
  3. [VIDEO] Install Adobe Flash Player on your Samsung Galaxy Note 3
    By chrisngrod in forum Samsung Galaxy Note 3
    Last Post: 12-08-2013, 01:20 PM
  4. dirty flash CM10?
    By bstillwell15 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 10-15-2013, 04:15 PM
  5. flash player problems
    By brerspidur in forum Samsung Galaxy Note 3
    Last Post: 10-14-2013, 11:07 PM
