Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By tube517
    Default Galaxy Note 1 I717 Stock Flash won't fix boot loop
    I received a Galaxy Note 1 I717 (AT&T) and it was in a bootloop. I have experience with flashing stock roms through Odin and fixing bootloops that way. So after going through recovery mode, wiping, flashing, I am still getting put into a bootloop after a successful flash on Odin. I've spent 2 days with this and tried all the little suggestions of wiping before flashing, using the original roms from XDA , trying some other stock roms specifically for my model and I'm still left with a bootloop. I'm capable of getting into download and recovery, and I've actually gotten different stock recovery modes! So the flashes are working, but it just won't boot up correctly. I looked around for the U.S. version of the Pit CSC Phone and PDA to try and re partition it, but they are absolutely NOWHERE! Any help would be greatly appreciated, whether it's a ROM suggestion, the re partition files, or whatever else.
  2. #2
    Default Re: Galaxy Note 1 I717 Stock Flash won't fix boot loop
    Where you able to fix the issue? I've been struggling with my i717 tried so many roms if i don't get the bootloop in the "optimizing apps" i get it on the configuration
    I couldn't find any solution to it. I had my buddy look at it to and he couldn't find anything to it either, our problem might have been hardware.
  4. #4
    tube517's Avatar
    Posts
    ROM
    Decks Reloaded,RebelROM
    Might be a stuck power button. It's a common issue on the i717
    TOSHIBA Thrive • Pio's Team Baked BlackBean 4.1.2 ROM
    Samsung Galaxy Note 1 (i717) • CM11 4.4.2 kitkat (jamied)
    Samsung GalaxyTab 3 (7 in) • Deleterious ROM
    HTC EVO 4G • Deck's Reloaded ROM
    Samsung Galaxy Note 2 (i317) unlocked • Ditto Note 3.1.1 (4.3) ROM
    B&N Nook Color (Gifted to relative)
    Samsung Galaxy Prevail • Half A$$ed ROM
    EVO Shift• JellyBelly ROM
    Samsung Galaxy S3 • DanKang 4.3.1 ROM
    Thanked by:
    Donald Bough likes this.
    How would I go about fixing something like that?
  6. #6
    tube517's Avatar
    Posts
    ROM
    broken power button? - xda-developers
    This thread may help. I don't have the issue but something here may help. Good luck!
    Thanked by:
  1. HTC One Bricked While Flashing ROM, No Back Up, No RUU
    By veddar83 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 07-01-2014, 11:56 AM
  2. Adobe Flash
    By BKVic in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-23-2013, 11:43 AM
  3. [VIDEO] Install Adobe Flash Player on your Samsung Galaxy Note 3
    By chrisngrod in forum Samsung Galaxy Note 3
    Last Post: 12-08-2013, 02:20 PM
  4. dirty flash CM10?
    By bstillwell15 in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 10-15-2013, 05:15 PM
  5. flash player problems
    By brerspidur in forum Samsung Galaxy Note 3
    Last Post: 10-15-2013, 12:07 AM
