Results 1 to 6 of 6
    nepotist's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Please Help, I think I brick my phone
    Hello,
    I will mention every thing I did since Yesterday so that it can help you guys in helping me.
    1) I used the following link to root my phone
    Galaxy Note Root Guide | Root Galaxy Note
    I was successfull.
    2) After the first step, I connected my phone to Kies and it said there is a upgrade version available and I did upgrade it to 4.3.
    3) Worked fine, but when I went to install Titanium Backup, it gave me a message saying that root access was denied and I need to root my device, smiliar message was given by SuperUser app.
    4) So I followed the instructions from this thread and was able to successfully complete till Step 4 (A) provided in the following link
    [REF] Start up guide for rooting, recovery, ROMs, de-brick, and tether updated 05/23 - xda-developers
    After completion of step 4 (A), my phone rebooted itself and freezes at SAMSUNG screen.
    Can someone please help me fix this, If I need to post this thread somewhere else, please let me know.
    Thank
    Nepo
    PS: I can still however go to the CMW recovery screen.
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Default Re: Please Help, I think I brick my phone
    Welcome to Android Central
    This looks like a soft brick so far. Boot into CWM and wipe cache partition. Then see if it boots up normally again
    nepotist's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks UJ,
    I have tried it many times and it still does do it. It gets stuck at the Samsung logo.
    Any other suggestions?
  4. #4
    xceeder's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Connect to your pc but don't use kies, connect as a normal mass storage and go on Google and get the stock rom for the note and place onto SD card then reboot your phone into recovery and flash the stock rom if an update comes through then accept it then start the rooting process... I hope this helps and I've wrote it clear enough for you
    Sent from my Nexus 7 using Tapatalk
  5. #5
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Default
    Quote Originally Posted by xceeder View Post
    You can't flash stock ROMs in recovery mode...
    Only Odin or the mobile Odin app work for flashing those.
    OP, get a stock tar file and flash it with Odin like you did with the root file. This will give you stock recovery and break root but it'll probably fix the issue
    Sent from my Galaxy S4 running SlimKat 4.4.2
    nepotist and tube517 like this.
    nepotist's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks UJ,
    I found a ATT stock ROM and was able to finally get it started. It gave many errors that with for all the apps were crashing. So i finally have a back up of my contacts and necessary stuff.
    I am now willing to mess with my phone as much as I can.
    Could you please tell me how can I get this device updated? If possible provide me with a working links with instructions.
    (I have tried previous links, but now I get a error message in Odin "Cannot Open Serial/com (Port)")
    I would greatly appreciate it.
    Also can please tell me how to update my CMW recovery.
    Thanks!
    Edit:
    Got everything to work.
    Thanks
  1. Replies: 7
    Last Post: 02-25-2014, 04:49 PM
  2. help
    By Celina1717 in forum General Help and How To
    Last Post: 02-20-2014, 10:33 PM
  3. help - water damaged S3 keeps restarting
    By Celina1717 in forum Samsung Galaxy S3
    Last Post: 02-20-2014, 09:59 PM
  4. Outbound texts seriously delayed - phone or carrier?
    By Rooster99 in forum General Help and How To
    Last Post: 02-20-2014, 09:22 PM
  5. help!!
    Last Post: 02-20-2014, 08:13 PM
