Results 1 to 7 of 7
    Default Not sure how this works. Do you think the SG2 will be Sandwich...
    Not sure how this works. It's my first android. Does it work like iPhones? Do you think the SG2 will be able to have sandwich installed on it?
  2. #2
    OptimusNotPrime's Avatar
    Posts
    Global Posts
    159 Global Posts
    ROM
    AOKP M5
    Default
    It will have it
    sent from my CM7 Thunderbolt
    Om Nom Nom Nom
  3. #3
    ijip's Avatar
    Posts
    Global Posts
    958 Global Posts
    Default
    Yeah the question is timing...I'm guessing nothing before Feb....
    Sent from my SAMSUNG-SGH-I777 using Tapatalk
  4. #4
    psufan32's Avatar
    Posts
    Global Posts
    330 Global Posts
    Default Re: Not sure how this works. Do you think the SG2 will be Sandwic
    Reports from the Nexus event is that pretty much every Gingerbread (2.3) device will be getting ICS.
  5. #5
    Is there anything unique to the new devices (hardware) that come with ICS that the SG2 does not have? I know there is only one device so far. I think I heard that most of the buttons are gone so you get a front that is almost all screen. Is this a ICS standard?
    Thx
  6. #6
    From Samsung & ATT? prolly mid next year. From CM? Hopefully this year.
    I like the features they add to ICS....but is it just me or ICS just doesnt look completely polish from that video stream shown last night?
  7. #7
    jsntrenkler's Avatar
    Posts
    Global Posts
    1,839 Global Posts
    ROM
    unNamed v2.2.1
    I would suspect that we will see the OS sooner likely around christmas time. Spec wise the GS2 actually has a slightly faster GPU so the experience should be the same on both (minus the display resolution)
