cynogenmod 7 help
mpazevedo
205
16
iskor12
88
5
Don't use ROM Manager on your AT&T S2. It will mess up CWM
Download Odin and flash this on your phone...
CLOCKWORKMOD-RECOVERY FOR GALAXY S II (AT&T)
Instructions
  • Power your device off
  • Boot into Download-Mode using Volume Up + Volume Down + Power
  • Hit Volume Up to accept the warning
  • Start Odin
  • Choose "SGH-I777_ClockworkMod-Recovery_X.X.X.X.tar" as PDA (no repartition)
  • Connect your Phone
  • Start flashing
Usage
  • Volume Up + Power brings your Phone into Recovery Mode.
  • VolUp + VolDn = Highlight Up/Dn
  • Power = toggles menus off/on
  • Home = Select
  • Back = Back
Now you will have to download the ROM and put it on your SD card. You can install it from there.
Download:
Multiupload.com - upload your files to multiple file hosting sites!
Anymore questions...feel free to ask.
iskor12
88
5
The name of the File doesn't change. You are simply looking on the wrong SD card. There are 2 options for selecting from an SD card. I think you need to select the Internal SD option.
shansmi
367
17
Read the install directions on XDA! multiple times if necessary. this is one of the more complicated ROMs to install and they tell you that up front in their thread on XDA.
