Results 1 to 5 of 5
    gsrrr's Avatar
    Derp
    Posts
    Global Posts
    75 Global Posts
    Default Possible to control vibration notification settings?
    This phone is awesome but I feel it vibrates for a really long period of time for notifications. Would it be possible to control the way the phone vibrates with alerts/notifications (length and/or pattern of vibration)? I've look through the phone's settings and could not find an option to do this, only to turn it on or off. I've also searched the android market for an app that would be able to do this but came up empty handed.
    Thanks
  2. #2
    Default Re: Possible to control vibration notification settings?
    Quote Originally Posted by gsrrr View Post
    Thanks
    dont know about the length of the vibration but you can change the intensity.
    Settings>Sounds>Vibration Intensity
    gsrrr's Avatar
    Derp
    Posts
    Global Posts
    75 Global Posts
    Quote Originally Posted by j510 View Post
    Thanks but I think that is just for the hepatic feedback vibration.
  4. #4
    Donmeister85's Avatar
    Posts
    ROM
    AOKP'ing it.
    There's an app in the market called Custom SMS Tones. You're able to customize your own vibration patterns for sms. It doesn't work for emails though. I do believe there is another app in the market that allows you to customize all notifications though. Can't remember what it's called. Just search for Custom SMS Tones and then scroll down to the bottom of the page for apps similar to Custom SMS Tones.
  5. #5
    Kiel's Avatar
    Posts
    Global Posts
    37 Global Posts
    I knew my liver felt strange after using this phone
    I'm just teasing, you meant "haptic"
