Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Fryguy128
    Default Help!! WIFI Issues
    I recently rooted my phone and am now having wife issues. My wife was working fine then I flashed another kernel and couldn't get wifi. I then updated the phone and it worked again. I changed the kernel again and can now not access wifi. There aren't any updates so I need help.
  2. #2
    Default Re: Help!! WIFI Issues
    You don't mention what kernels you are flashing. I have been using Cyanogenmods ICS nightlies for a couple of weeks now with no problems and wifi is great.
  3. #3
    webbie2's Avatar
    Posts
    ROM
    Stock Android 4.0.3
    did you fix the issue... thinkin about rooting. like to here when you resolve the issue.
    Default
    I fixed the problem by flashing SHOstock. I would definately recommend rooting to you I love it so far except for the occasional problems that are very easy to fix with a quick Google search.
    Thanked by:
    webbie2 likes this.
  5. #5
    Default
    I am ALWAYS having WIFE issues lol
    sent from my totally tubular Samsung galaxy s2 sgh-I777
    Thanked by:
