Results 1 to 4 of 4
    Default Will rooting allow my to connect phones wifi?
    I just purchased a sony s tablet (wifi only). I dont want to pay 30$ every month to use wifi outside on tablet. If I root my att gs2 will that allow my tablet to use it as wifi on the go?
    Sent from my Sony Tablet S using Tapatalk 2
  2. #2
    Default
    Rooting is literally just the first step. There are apps in Google play market that can accommodate what you are trying to do. There are also a few apps that I thought didn't require root, but not sure how well they work.
    Sent from my SGH-I777 using Android Central Forums
  3. #3
    TechFitGJ's Avatar
    Posts
    Global Posts
    85 Global Posts
    ROM
    JELLY BEAN!
    Default Re: Will rooting allow my to connect phones wifi?
    The short answer is, yes. You can download the Wifi Tether app.
  4. #4
    Nevets68's Avatar
    Posts
    Global Posts
    99 Global Posts
    Use FoxFi...no rooting needed. Just install , configure and use .
