Results 1 to 9 of 9
    lynn02's Avatar
    Posts
    Global Posts
    59 Global Posts
    Default Battery fully charged sound
    I use my phone's alarm clock and plug it in to charge at night. The sound it makes when it's fully charged wakes me up. Is there anyway to turn that sound off?
  2. #2
    Default Re: Battery fully charged sound
    Turn the volume down for the alert. The alarm should have its own volume control.
    Sent from my SGH-I777 using Android Central Forums
  3. #3
    Hey let me know if the alert volume affects it. You must be a light sleeper. As far as I know from my own experience you are unable to lower the volume unless the phone is complety silent/vibrate mode.
    lynn02's Avatar
    Posts
    Global Posts
    59 Global Posts
    I didn't see just an alert volume.
    Thanked by:
    j510
  5. #5
    OK, I'm running CM10 so maybe you can't with the stock ROM.
    Attached Thumbnails Attached Thumbnails Battery fully charged sound-uploadfromtaptalk1349230838846.jpg
    lynn02's Avatar
    Posts
    Global Posts
    59 Global Posts
    I'm not rooted. I'm guessing that will probably be the only way to get the option to turn that sound off.
    Thanked by:
    j510
  7. #7
    Mine does not beep when fully charged...it turns the screen on
  8. #8
    Install the Battery Charged Silencer - you can mute that sound if it occurs during certain hours of the day. I had the same problem and the app works beautifully. No more waking me up in the middle of the night!
    Thanked by:
    lynn02
    lynn02's Avatar
    Posts
    Global Posts
    59 Global Posts
    Thank you!! I will look for that.
  1. Screen burn in from battery fully charged message
    By Mojave in forum Verizon Fascinate
    Last Post: 04-27-2011, 05:58 PM
  2. Fully Charged Battery Dying Overnight :(....Again
    By SFGiants 2010 in forum Verizon HTC Thunderbolt
    Last Post: 03-26-2011, 11:39 AM
  3. Using Scanner Radio to fully charge the battery
    By willy900wonka in forum HTC EVO 4G
    Last Post: 11-26-2010, 09:38 PM
  4. 2600 mAh battery won't fully charge?
    By rosariorose9 in forum Verizon Droid Incredible
    Last Post: 07-14-2010, 06:05 PM
  5. Replies: 3
    Last Post: 12-14-2009, 06:44 AM
