Results 1 to 7 of 7
    Default Help!! My s2 keeps resetting itself and nothing seems to be working to fix it.
    Hey guys. My galaxy s2 keeps rebooting by itself. It started doing this last night and hasnt stopped since. It turns on normally but after about 3 or 4 minutes it'll freeze up and after about another minute it'll completely reboot. I've removed the SD card until it fully booted but that didn't help any. I've also left the battery out of the phone all night (which was about 12 hours) and it still didn't fix anything. Sadly, money is an issue here as I'm flat broke because of the holidays. Is there anyway I could possibly fix this myself and free of charge?
  2. #2
    Foramex's Avatar
    Posts
    Global Posts
    205 Global Posts
    Default Re: Help!! My s2 keeps resetting itself and nothing seems to be working to fix it.
    Quote Originally Posted by Chris Marlar View Post
    First of all, welcome to Android Central Forums!
    Second of all, did you download any new applications lately? Perhaps it's a new application that's causing the re-booting.
    If you can't think of any new applications you downloaded lately, perhaps you could try and reset the phone. This might fix problems, especially if you have the phone for a long time.
    Proud LG G2 Owner!
    I've actually not downloaded any apps recently so I don't think that could be the problem. :s And I'm really sketched out about resetting the phone because of the personal stuff I have saved on there and I don't have backups. I would move it all to an SD card but it only resets after it scans the card so I don't know how I would move it all before it reset.
  4. #4
    Foramex's Avatar
    Posts
    Global Posts
    205 Global Posts
    You could move it to the SD card, then take the SD card out of the phone, reset the phone, put the SD card back in.
    Proud LG G2 Owner!
  5. #5
    srkmagnus's Avatar
    Posts
    Global Posts
    6,754 Global Posts
    ROM
    Stock 4.4 (KitKat)
    I'd suggest a factory reset just to be sure anything that could be causing a issue is removed. That should address the problem. Be sure to backup any data that you can.
    I actually have a new problem now. Somehow the issue resolved itself for about 2 days and now its doing it gain. I tried doing a factory reset but it resets itself during the reset and therefore nothing happens. I fear that my phones in a permanent loop now. :/
  7. #7
    If your phone doesn't reboot until you put the SD card in, have you tried leaving it out to see if the problem goes away? If it does, then something may be wrong with the SD card and you should get a new one.
  1. Note 8 Tethered to S4 Mini for Air Watch Email
    By Andrew Grist in forum Samsung Galaxy S4 Mini
    Last Post: 01-03-2014, 05:21 PM
  2. Need help re: lock key
    By bEl500 in forum Verizon Galaxy S3
    Last Post: 01-02-2014, 12:16 PM
  3. Stock email client autofill addresses... how to edit them??
    By fotyc in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-02-2014, 11:23 AM
  4. Web page to home screen question
    By LosingMyMind in forum Samsung Galaxy Note 3
    Last Post: 01-02-2014, 10:52 AM
B
