Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Shanicenicolle
  • 1 Post By RobbieL811
    Shanicenicolle's Avatar
    Posts
    Global Posts
    1,896 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Was going to flash-didn't. Will otas still work?
    So I was going to flash cm10 and changed my mind. So I now have two questions
    1. When jb becomes available for ATT will I have to unroot?
    2. Should I Uninstall the cm recovery and if so, how would I go about this?
    Thanks in advance!
    Sent from my Red GS3
    Progrmmr likes this.
  2. #2
    RobbieL811's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Was going to flash-didn't. Will otas still work?
    Quote Originally Posted by Shanicenicolle View Post
    Thanks in advance!
    When the update becomes available through OTA, yes you will have to unroot. You can download Voodoo OTA root keeper & try that. If that doesn't work, you will lose root when you flash the Jellybean update. When you get ready to OFFICIALLY update your best bet is probably gonna be to flash back to stock firmware through Odin, essentially completely resetting your phone & then apply the OTA update from there. That is of course if the Voodoo app doesn't work. I've never used it so I don't know.
    Edit* He'll, I would continue to run CM10 until the update comes if you like it. You can take the steps I mentioned on the day of the update.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    Shanicenicolle likes this.
    Posts
    Global Posts
    1,896 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by RobbieL811 View Post
    Yea I'm leaning towards it I'm a little afraid to flash lol
  4. #4
    RobbieL811's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I wouldn't do anything thing that worried you even if it was just a little bit. Just wait a little while if you are uncomfortable flashing. The JB update SHOULDN'T be too far away but you never know with AT&T!!! If you need any help when it comes time to update, just PM me & I'll help as much as I can. It shouldn't be too hard though...
    Posts
    Global Posts
    1,896 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks I appreciate it. I used rom manager and got stuck on the splash screen for cm10, just reloaded Mt backup and I'm fine but I guess I'll just leave it be lol
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
  6. #6
    RobbieL811's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you want to download CM10, I always get it from get.cm. You have to make sure that you have your device selected on the left side of the page. If you have an at&t GS3, it would be d2att. Download the latest nightly & then boot into CWM manually & flash it that way. That's how I do it anyways.
    Posts
    Global Posts
    1,896 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I may try again this way then. I'll report back with the results!
  8. #8
    RobbieL811's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You know that you need to download the latest Gapps and flash them while you are flashing CM10 right.
    Posts
    Global Posts
    1,896 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yep! I read that the rom manager did everything but I guess not. I'll just dig up the tutorial I was going to use and try it that way
  10. #10
    RobbieL811's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just download goomanager from the play store. You can get the latest signed Gapps from there. Then download CM10 from get.cm. Then boot into CWM & flash as you normally do.
  1. Did anyone think it was going to be this bad?
    By bearballz72 in forum Sprint
    Last Post: 08-22-2012, 06:49 PM
  2. Unlock the bootloader if I am not going to flash custom Roms?
    By Gtronic in forum Sprint Galaxy Nexus
    Last Post: 05-03-2012, 06:40 AM
  3. Best Buy DID think it was going to be called the Nexus Prime!
    By Vance14 in forum Verizon Galaxy Nexus
    Last Post: 12-23-2011, 07:45 PM
  4. The "I was going to get the Evo 3D" Thread
    By tuna83 in forum Sprint Photon
    Last Post: 08-02-2011, 12:01 AM
  5. Replies: 2
    Last Post: 07-26-2011, 01:18 PM
