1. spartanrob1's Avatar
    Finally, one of my friends picked up an S3. We tried to send pictures by touching the phones back to back. The phones vibrated, the screen instructed me to 'tap to send' but ultimately, nothing happened.
    Any tips or tricks to get this to work?
    As a side note, his is Verizon, mine is ATT, his battery blows mine away. Must be the ATT network.
    12-03-2012 04:37 PM
  2. eddied042092's Avatar
    Hey, in case you haven't figured it out yet you should go in to the settings and make sure you have all the transfer stuff correct. Other than that i wouldn't be able to help sorry.
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
    12-11-2012 07:02 AM
  3. spartanrob1's Avatar
    Thanks. All settings are correct, still have not figured it out.
    12-11-2012 09:30 AM
  4. eddied042092's Avatar
    Even the setting in "more options"? Just making sure it doesn't hurt.. and i tried looking and found nothing yet but you should check if the transfer of pictures using the tap feature is supported between verizon and at&t.. it'd be stupid if it wasn't but you could always just check
    12-11-2012 02:38 PM
  5. spartanrob1's Avatar
    Thanks. The phones 'connect' with each other and vibrate, but the pics just don't send. Would be VERY suprised if it didn't work across carrier as the feature is not carrier specific.
    12-11-2012 03:41 PM
  6. eddied042092's Avatar
    Sorry about the wait.. yeah its weird. I have an att one and my friend's on tmobile and ours worked fine. We put the phones close up and it says "tap to send" and you tap it and give it a second or two and it'll send it then we moved the phones and the pictures were sent.
    12-16-2012 11:45 PM
  1. How to send music to S3 Microsd card...
    By gta50419 in forum Samsung Galaxy S3
    Last Post: 09-30-2012, 02:27 AM
  2. To send email to contact group with gmail
    By twgerber in forum ASUS EeePad Transformer
    Last Post: 05-28-2012, 11:18 AM
  3. Unable to send sms to a 6 digit number
    By almarsh78 in forum AT&T Inspire 4G
    Last Post: 08-22-2011, 05:30 PM
  4. how to send pics that you download from emails ect...
    By BKVic in forum Motorola Droid X
    Last Post: 12-19-2010, 12:22 PM
  5. Using Handcent to send text to email
    By spepi in forum Motorola Droid
    Last Post: 07-20-2010, 11:01 AM
