Like the title says, wondering if this is possible? Came across clearish replacement for batter cover still trying to find suitible material to go between hardware and battery cover, then led will "peek out" from material and sandwich between battery cover. Dont need led to change colors, just light up. Figure it would be easier to just change the battery cover to a diff color than learn the mechanics of multi color led or whathaveya. Thanks in advance.
Posted via DROIDcentralAPP on SSgS3
