- 11-27-2012, 01:47 PM
Thread Author #1
Was going to flash-didn't. Will otas still work?
So I was going to flash cm10 and changed my mind. So I now have two questions
1. When jb becomes available for ATT will I have to unroot?
2. Should I Uninstall the cm recovery and if so, how would I go about this?
Thanks in advance!
Sent from my Red GS3 - 11-28-2012, 01:27 PM #2
Re: Was going to flash-didn't. Will otas still work?
When the update becomes available through OTA, yes you will have to unroot. You can download Voodoo OTA root keeper & try that. If that doesn't work, you will lose root when you flash the Jellybean update. When you get ready to OFFICIALLY update your best bet is probably gonna be to flash back to stock firmware through Odin, essentially completely resetting your phone & then apply the OTA update from there. That is of course if the Voodoo app doesn't work. I've never used it so I don't know.
Edit* He'll, I would continue to run CM10 until the update comes if you like it. You can take the steps I mentioned on the day of the update.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2Thanked by: - 11-28-2012, 08:37 PM
Thread Author #3
- 11-30-2012, 02:38 AM #4
I wouldn't do anything thing that worried you even if it was just a little bit. Just wait a little while if you are uncomfortable flashing. The JB update SHOULDN'T be too far away but you never know with AT&T!!! If you need any help when it comes time to update, just PM me & I'll help as much as I can. It shouldn't be too hard though...
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2 - 12-01-2012, 05:56 PM
Thread Author #5
- 12-02-2012, 12:00 AM #6
If you want to download CM10, I always get it from get.cm. You have to make sure that you have your device selected on the left side of the page. If you have an at&t GS3, it would be d2att. Download the latest nightly & then boot into CWM manually & flash it that way. That's how I do it anyways.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2 - 12-02-2012, 08:34 AM
Thread Author #7
- 12-02-2012, 08:40 AM #8
- 12-02-2012, 08:45 AM
Thread Author #9
Yep! I read that the rom manager did everything but I guess not. I'll just dig up the tutorial I was going to use and try it that way
Sent from my SAMSUNG-SGH-I747 using Android Central Forums - 12-02-2012, 08:51 AM #10
Did anyone think it was going to be this bad?
By bearballz72 in forum SprintReplies: 51Last Post: 08-22-2012, 05:49 PM -
Unlock the bootloader if I am not going to flash custom Roms?
By Gtronic in forum Sprint Galaxy NexusReplies: 9Last Post: 05-03-2012, 05:40 AM -
Best Buy DID think it was going to be called the Nexus Prime!
By Vance in forum Verizon Galaxy NexusReplies: 23Last Post: 12-23-2011, 06:45 PM -
The "I was going to get the Evo 3D" Thread
By tuna83 in forum Sprint PhotonReplies: 45Last Post: 08-01-2011, 11:01 PM -
Was going to hold off -- but VZW just announced LTE next Month!
By p08757 in forum Droid BionicReplies: 2Last Post: 07-26-2011, 12:18 PM
Reply
