Transfer contents from a 32GB MicroSD Card to a 64GB MicroSD Card on GS3?
How can I transfer all (including hidden and/or system) files from one card to another?
If I do it from the Phone to the PC and back to the 64GB card all folders are not copies.
Conversely, if I do it from the PC card slot to the PC and back to the 64GB card all folders are not copied as well.
Any ideas and or pointers to apps or utilities would be appreciated.
Would a back up of the 32GB and restore to the 64GB work? if so, any recommendations for a backup app for a non-rooted GS3.
Thanks in advance,
Pete
Re: Transfer contents from a 32GB MicroSD Card to a 64GB MicroSD Card on GS3?
what isnt working?
I always have connected my phone to the PC, moved the files to the PC in a folder of its own, swapped cards, plugged the phone back in, then move the files to the new card...everything is there..
Please list what is not coming across. I do this all the time with just drag and drop (in the phone or PC). Everything works fine.
Are u using Windows?
If you have a card reader on your laptop, use that to transfer
Also if you want to view hidden files
Open Folder Options in Control Panel.
- Click Start, and then click Control Panel.
- Click Appearance and Themes, and then click Folder Options.
On the View tab, under Hidden files and folders, click Show hidden files and folders.
Then transfer all those to your other MicroSD card
