Nicole,
Just FYI, this is how my problem initially began. My GPS would randomly not find any satelites unless I cleared out the maps Cache, or deleted any updates.
Also, I think I may have found the issue. I use the Phone for several hours a day, and have my phone plugged in using a car charging port. My phone was getting pretty hot while using the GPS, and I'm wondering if the prolonged use, and constant charging may have burned out the GPS in all three devices. I am shocked if that's the case... but I'm wondering if it could be a structural issue with the GPS due to overheating... thoughts?
It's a verizon charger, but I'm using one of those outlet converters that you plug into a power socket.
I'm getting my 4th phone, and will avoid using a charger in the car... see if that takes care of it, will let you all know. Thanks for the input.
