- 12-04-2012, 11:18 AM
Thread Author #1
HELP!!!! How to get more than edge data with tmobile using the unlocked at&t Galaxy s3
I was suckered into buying the tmobile service bc the jackhole told me everything would work fine with my unlocked phone little did I know that the service was edge!!! Is there anyway to upgrade this??? I can't live with edge data???
- 12-04-2012, 11:32 AM #2
Re: HELP!!!! How to get more than edge data with tmobile using the unlocked at&t Galaxy s3
From what I understand, T-Mobile does not have LTE. If you didn't get a phone from there, there is no reason you should have a contract. The only reason for contracts is to get good prices on phones.
- 12-04-2012, 12:55 PM
Thread Author #3
- 12-04-2012, 07:34 PM #4
Well actually, my sister had an unlocked iphone and they put her under contract at AT&T and they quickly rectified the error when I told my sister and she said something about it.
When I took my T-Mobile phone to AT&T and I had it unlocked, it still wouldn't even connect to the AT&T data network so I had to get a new phone.
You might want to try in the S3 T-Mobile forum since people in that forum will be familiar with T-Mobile and what, if anything, you can do.
http://forums.androidcentral.com/t-mobile-galaxy-s-iii/ - 12-05-2012, 12:30 PM #5
Since it sounds like you live in an area where T-Mobile hasn't lit up their frequencies they got from AT&T you won't be able to get 3G data on your AT&T SGS3. My suggestion is to go back and get a refund from T-Mobile. Or sell your AT&T SGS3 and buy a T-Mobile SGS3.
Get rid of all the randomness in the world and you will have a world without hamsters. - 12-05-2012, 04:15 PM #6
If I remember correctly, Tmobile operate's it's 3G spectrum on the 1700Mhz AWS frequency which AT&T doesn't currently use. All you'll ever see is 2G/EDGE.
Possible Errors Between Keyboard And Chair.
How to Get more internal storage space Help
By countmypennies in forum Optimus V Rooting, ROMs, and HacksReplies: 30Last Post: 05-04-2013, 11:07 AM -
How to get only 1 email notification with 2 accounts
By MJ2002 in forum General Help and How ToReplies: 0Last Post: 08-31-2012, 09:45 PM -
How to get more _internal_ memory
By dmullens in forum AT&T LG Phoenix/ThriveReplies: 5Last Post: 11-28-2011, 12:43 AM -
HELP: How to get to stock from CM7
By ryman222 in forum LG Optimus S Rooting, ROMs, and HacksReplies: 4Last Post: 05-15-2011, 05:19 PM -
How can I get more than one email address to be available without switching?
By Ally-oop in forum HTC Droid ErisReplies: 1Last Post: 11-19-2010, 09:42 PM
Reply
