Results 1 to 6 of 6
- 12-27-2012, 12:20 PM
Thread Author #1
Maps draining battery when navigation not used
Guys I am really having a time with my battery life on my GS3. Frequently, I will leave my phone in the car while at work (my office is in the lowest level of a building and cell service is non-existent due to the building design) to keep from needlessly draining the battery. Often though, at the end of the workday, I will get in the car to go home and notice my battery is around 40% left. Now, keep in mind, the phone has been screen off and it's just been sitting still the entire day, so navigation isn't being used, however if I look at battery usage, "MAPS" is often the #1 offender as far as usage goes, sometimes 2-3 times as much drain from it than the OS. I have "report from this device" disabled in Maps-location Settings, thinking that might help, but nope, no help. I'm really at my wits end, can anyone help me out or give me some tips? I am still pretty new to the Android ecosystem, but I'm doing everything I can think of and find, to remedy the battery life, but nothing seems to be helping. This is on an AT&T GS3 with Jelly Bean.
- 12-27-2012, 08:22 PM #2
- 12-27-2012, 11:35 PM #3
Re: Maps draining battery when navigation not used
this is a problem for me too. I ended up disabling the app, but I really hated having to do that. I would use it every now and then,but I havent used the app in more than a week. will see if the tips at that link will help.
- 12-28-2012, 07:41 PM #4
- 12-31-2012, 09:34 AM
Thread Author #5
But how is it geotagging if nobody else can see it? Seems like the only person that can see this is me. I appreciate the tips, I'm going to see if these make any difference, but I'm a bit skeptical.
- 01-02-2013, 10:04 AM #6
Maps not used but using battery, sensors, keep awake
By sslayer in forum Verizon Galaxy S3Replies: 17Last Post: 04-24-2013, 02:13 PM -
How much battery are you losing an hour when NOT using your Prime
By SpikeJones in forum ASUS EeePad Transformer PrimeReplies: 9Last Post: 01-22-2012, 07:15 PM -
Battery drain when navigation is being used
By Krazyhaze in forum AT&T Samsung InfuseReplies: 3Last Post: 05-29-2011, 02:52 PM -
Battery dieing while not using phone....
By Brad48 in forum HTC myTouch 4GReplies: 1Last Post: 01-18-2011, 02:04 PM -
Major Phone app bug when not using Sense
By Blubble#AC in forum HTC EVO 4GReplies: 11Last Post: 06-14-2010, 10:35 AM
Reply
