Results 1 to 5 of 5
    Default Help S3 is Stuck in roaming or does not get signal!
    So here's the situation. I changed out my LCD digitzer in my phone. The re-assembly went smoothly however I get no signal or I am stuck in roaming. The antenna connector to the motherboard is snapped in I tripled checked it. I also have my sim card in the slot. I've tested my phone in the samsung galaxy secret menu using *#0*# and everything is working. Just no signal. Please give me some guidance or advice
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Help S3 is Stuck in roaming or does not get signal!
    Quote Originally Posted by adam041590 View Post
    Welcome to the forums! This might sound rhetorical, but it isn't: Are you in a coverage area?
    Yes I am. I've also checked the settings and it says It is not recgonizing a network nor a mobile network or anything for that matter :/. Everything else is working perfect though
    Ok so WiFi works this means It must have something to do with the phone not being able to go into my carrier's network. But changing the digitizer should not cause this problem should it?
  5. #5
    I have experienced this exact issue. I replaced my digitizer, complete LCD and front frame (process all went smoothly) and now it has very weak signal with pop ups saying 'no network coverage' if i try to call or text. I brought a cheap LCD (non genuine) but everyone's saying this shouldn't affect its signal. I've had it professionally master reset by a Samsung dealer and even replaced the antenna. Very frustrating!!
  1. After 4.2.2 S Planner list view is off by a day
    By RedV412 in forum Samsung Galaxy Note 8.0
    Last Post: 11-10-2013, 07:15 PM
  2. Trying to get to wifi but going crazy!
    By JGK123 in forum Google Nexus 4
    Last Post: 10-19-2013, 03:46 PM
  3. What SD card is recommended for Note 3?
    By WillYammer in forum Samsung Galaxy Note 3
    Last Post: 10-19-2013, 02:57 AM
  4. Not starting up all the way
    By CodyshaneO in forum Sprint Samsung Galaxy S4
    Last Post: 10-18-2013, 04:22 PM
  5. GS3 will not connect to PC sgh_t999
    By dylanwelch95 in forum T-Mobile Galaxy S3
    Last Post: 10-18-2013, 03:42 PM
