Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By GSDer
    Default Battery goes from 100% to 15% in less than 2 hrs.
    I'm not sure how to solve my battery issue. I can charge it all night, take it off the charger with 100%, and by the time I get to work and check it, which is about 1.5 hrs later, it is down to 15% with NO usage. Within the next couple hours it is down to 10%. I keep the screen low, no apps are running. When I look at the battery usage, the top usage is the Android System with 23%, then screen, then Android OS, Google Services... I can't imagine this is normal, it is now down to 10% with 3 hours off the charger.
    Phone is almost a year old, bought from AT&T store. Anyone know what to do to fix it?
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,863 Global Posts
    ROM
    Stock Moto X
    Default Re: Battery goes from 100% to 15% in less than 2 hrs.
    Quote Originally Posted by DanielleG88 View Post
    Welcome to the forums.
    The battery may be bad. I would try replacing that first.
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu
    Community Guidelines and also here
  3. #3
    It's not the battery that's bad unfortunately its the phone that sucks on battery level. I love this phone but the battery drainage I hate & sometimes it gets extremely hot too... what u can do is try "Juice defender" download it from the playstore, it helps a lot.
    Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
  4. #4
    Quote Originally Posted by abarzua21 View Post
    Please don't speak for the OP - you don't know WHAT that person's issue is. Let's hear back from the OP and then any further assessment can take place.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
  5. #5
    Posts
    Global Posts
    13,863 Global Posts
    ROM
    Stock Moto X
    I am inclined to agree with GSDer. A 90% drain in less than 4 hours is excessive.
    From a Sprint Moto X using AC Forums app
  6. #6
    DanielleG88,
    Any attempt to diagnose battery life issues usually starts with the following:
    - capture these three screenshots from Settings -> Battery- be sure the data starts with the phone fully charged
    - try to let the battery get depleted to less than 30% (shouldn't be a problem in your case)
    - don't charge the phone between the full state and whenever you decide to capture the data
    You might find it helpful to install Wakelock Detector: - this will help to identify any apps that are keeping the phone awake unnecessarily.
    This GSam Battery Monitor Pro: (there's also a free version) can also be useful, particularly the Radio Detail information
    KreepyKen likes this.
  7. #7
    I had this same problem with my android phone...battery while charging used to stuck at different levels and when i unplugged the charger it at once dropped to low level. The problem is with the battery stats.It is showing the battery charge level wrong.
    Solution: Use all the charge in the mobile till it is dead. Put on the the phone again to see if it is totally dead. when you are sure of it plug the phone into electricity with the phone off for 1 hour at least. Now turn on the phone it must be okay by then.
    P.S I would also suggest that you use the charger that came with the phone rather charging it with a random charger because this matters too.
    Thanked by:
  1. Verizon G2 in white... FREE
    By JJ Jones in forum Verizon LG G2
    Last Post: 12-10-2013, 10:50 AM
  2. Chrome Tab casting 720p from an 8" tablet with no lag!
    By lostchild in forum Google Chromecast
    Last Post: 12-06-2013, 03:55 PM
  3. Battery monitor on lock screen
    By caseyatc in forum Moto X
    Last Post: 12-03-2013, 08:37 AM
  4. Replies: 3
    Last Post: 12-02-2013, 04:54 PM
  5. ZTE tethering to tablet
    By Dorste in forum Other ZTE Android Phones
    Last Post: 12-02-2013, 07:37 AM
B
