Results 1 to 4 of 4
    Default Battery problem
    Hi everyone, I am new here and hoping someone can help me!
    Long story short, I got my galaxy s3 stolen last weekend. I had a water damaged one from a while back that has been sitting in rice every since it got damaged. I had it cleaned out and looked at today, and the person who looked at it said every thing looked fine but he wasn't able to look at the battery part yet. I took it to a ATT store and put a different battery into the phone. The phone will vibrate when pushing the on button, and with the other persons batter in there it tried turning on. It will just show the battery symbol and and then stop. Occasionally it will do this without me touching it. Sometimes it shows up when there is no battery in there at all. I was wondering if anyone would be able to tell me what part of the phone I would need to be replaced. I am trying to attach a picture of what the battery does but it is not working!
    Edit:
    Thank you!
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,710 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Battery problem
    Welcome to the forums!
    I have no idea what to suggest,but I at least wanted to say hi.
    From a Liquid Nexus 5
  3. #3
    Quote Originally Posted by jennad123123 View Post
    Edit:http://i62.tinypic.com/qs7hbo.jpg
    Thank you!
    To be honest you are best just getting a new phone it will probably be cheaper than keep paying for different things to be fixed...
    Sent from my Nexus 7 using Tapatalk
    Hi Golddriver and thank you xceeder. I figured that was what I should do. I had it cleaned out and looked at from a friend so I didn't have to pay. I was just hoping there was something cheap I could do since it looks like the screen works. I am using the HTC inspire until I can get the S5, it is just kind of a downgrade for me so I don't like it as much hahah. I guess it will have to do until September or October. I just hope that comes quick!
  1. HTC One (M8): Dot View Case hinge - Is it a problem?
    By karaze49 in forum HTC One M8 Accessories
    Last Post: 04-03-2014, 12:19 AM
  2. Galaxy S3: battery saving setup
    By saab61 in forum Samsung Galaxy S3
    Last Post: 04-01-2014, 09:51 AM
  3. SN3, Kit Kat and battery charge
    By wendy5001 in forum Android 4.4 KitKat
    Last Post: 03-30-2014, 12:13 PM
  4. need help with audio problem
    By huxley001 in forum Acer Iconia A100
    Last Post: 03-29-2014, 11:57 PM
  5. Google+ doing insane battery drain?
    By JnEricsonx in forum Android Apps
    Last Post: 03-29-2014, 06:18 PM
