1. Wetzel267's Avatar
    Hey guys!
    I've done some extensive research and tried a lot of options but I've not been able to locate this issue yet. I've had this GS3 for a few weeks now and i've noticed every 2-3 days the battery will start to drain at a rate of 1% ever 4-5 minutes and a simple restart fixes it (Screen off and all apps closed out. This is not a huge issue since I glance at my phone every now and then and am able to catch it before it loses more than a few percentage points. Here are a few things i've noticed:
    The drain seems to happen later in the day usually when.
    The drain 4/5 times will occur after I switch from 4g to wifi or vice versa.
    I have not been able to single out an app yet but i've been trying to keep a note of what apps I use before the drain occurs.
    Installed apps:
    Twitter
    Instagram
    gmail (auto sync off)
    Chrome
    Reddit is Fun
    Snapchat
    Wakelock Detector
    I installed wakelock detector a week ago and started analyzing the stats as soon as a drain starts to occur. I've noticed that NFC service is always red (running) and messaging is as well.
    I got a screenshot of the kernel for you guys as well.
    I appreciate any help you can offer. The fact that a restart fixes it makes me think it is an app or a service that is causing it so I do not think the phone is faulty. Its not a huge deal, even with this battery drain issue (assuming I catch it) I still get at least 20 hours of charge off this thing with 3-4 hours of screen time.
    Thanks!
    04-23-2014 05:19 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The next time the battery drain starts, let it happen for a little while, then post a screenshot of the battery stats so we can see what apps or services are using a lot of juice. You might want to install GSam Battery Monitor as well, which can give a more detailed breakdown than the native battery settings.
    04-23-2014 10:00 PM
  3. Wetzel267's Avatar
    Sure, will do!
    04-24-2014 06:57 AM
  4. ddcripple's Avatar
    I have the same situation, here is a snap of my battery stats. Galaxy S3 Random Battery Drain Issue.-10169232_10202912670191463_1270486188372611096_n.jpgGalaxy S3 Random Battery Drain Issue.-10426308_10202912667591398_1574397506602629287_n.jpg
    05-28-2014 07:47 PM
  1. Galaxy S5 Bluetooth with Dodge Dart UConnect system.
    By sirmaru in forum Samsung Galaxy S5
    Last Post: 06-15-2014, 04:20 PM
  2. Replies: 23
    Last Post: 05-02-2014, 01:58 AM
  3. issue with my s5
    By greatguyokay in forum Samsung Galaxy S5
    Last Post: 04-23-2014, 05:12 PM
  4. HELP! Calendar Issues with changing repeat events.
    By LGPhoneIssue in forum Verizon LG G2
    Last Post: 04-23-2014, 05:08 PM
  5. microsoft exchange issue
    By Jonathan Sher in forum Samsung Galaxy S5
    Last Post: 04-23-2014, 04:19 PM
